Home > Help Needed / General Tech Chat > Core plugs
Believe it or not this is a job that I have never done.
Obviously all I have to do is tap them in.
But any tips or advice that I might not know about having not learnt by experiance.
cheers
Wil
Pretty simple as you suspected. I removed the old ones, cleaned the block slightly with some fine sandpaper and tapped the new ones home using a suitably sized socket. I know some people put some loctite on the edge of the plug when fitting to make a good seal.
Phil. *smiley*
Nick
Member #: 154
Midlands
stick the plugs in the freezer overnight aswell...
Mike
Member #: 107
Sunny Sussex
grr beat me to it, that was my only tip!
Dangerous
Member #: 417
I put a bit of household silicon sealer on before fitting
