Home > Help Needed / General Tech Chat > are these normal?
Carl
Member #: 95
liverpool-on-sea
my turbos been up and running for a couple of months now and hopefully ive sorted my teething probs(fingures crossed)
but ive never driven another mini turbo or been in one so i would appriciate it if some of you could let me know if some of these things a normal
1) when turbos on full blow and i come of the gas i get a dump valve whoooossssing type noise (not dead loud)all though im running totally standard
2)when the engines hot and i turn it off if i go back to start it up after about 15 to 30 mins it takes a while of cranking to get it going
3)oh and it seems to torque steer quite a lot under hard acceleration,which makes me laugh quite alot and i dont think 13 by 7jj wheels help?
at the moment these are the only 3 things i can think of and although there not big probs id like to know whether something needs loking at or are they pretty normal?
many thanks
carl *smiley*
Edited by Carl on 5th Mar, 2004.
minimark
Member #: 19
newcastle
1. pop off valve in plemum chamber , releasing boost which no where to go as butterfly in carb is shut.
2. heat soak in carb from hot turbo , cranking is pumping cold fuel in , until it fires , make sure heat slield is fitted, got some holes in bonnett to allow hot air out, or live with it.
3. 13x7`s not good , check off set of wheels and get front end set up , ie castor + chamber.
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
2: I had the same pb with my turbo, when it arrive start the engine with wide open throttle, evidently close it immediaty when the engine start *smiley*
fab
