Home > 998cc > roller rockers
martpaul
Member #: 668
newton aycliffe (near durham)
Hey all
Just getting my list of parts together!
what type do you reckon i should use for these?
any suggestions would be great! oh its for a 998cc turbo!
More info needed!
Camshaft you are using? Cylinder head? Valve sizes? Turbo?
martpaul
Member #: 668
Right as suggested im gonna use the mg metro cam, 12g295 head (untouched) with standard valves and a t2 turbo!
Im building it so i know how to do it with my uncle then taking it from there mod wise!
hope this helps!
martpaul
Member #: 668
have i got the right idea?
I'd say go for 1.3:1 ratio rockers. I think with the MG cam in a 998 the 1.5:1 rockers may make the engine a bit extreme for road use.
TBH unless you have a huge budget you may be just as well to stick with the standard sintered rockers.
martpaul
Member #: 668
cool i tink ill stick with the standard ones then,
then when i start to mod it i can look then!
cheers!
martin
Graham Harvey
Member #: 568
EFI A Series Turbo
Burntwood Staffs
Tom is right,stick with the standard 1.3 ratio rockers,my 998 turbo,using an Avonbar phase 2 cam,12g295.IHI RHB5 turbo, made 5bhp less using 1.5 ratio roller rockers.These were changed over on the rolling road on the same day,so there were no other variables to explain the lost 5bhp.
Graham
Everyone who has tried the ph2 with 1.5s has had a similar result Graham, 1275s and 998s
Graham Harvey
Member #: 568
EFI A Series Turbo
Burntwood Staffs
The ph2 cam I use is the earlier one I think,it has had nothing special done to it to suit the 998cc.
I used this cam in the 1293cc engine as well,it made the same power as the kent 500,which I think is a copy of the MG Metro cam,it just moved the peak power 1000rpm up the rev range.
Graham
