Home > Help Needed / General Tech Chat > Will this actuator fit my T3?
http://cgi.ebay.co.uk/ACTUATOR-31-ESCORT-R...1QQcmdZViewItem
Dangerous
Member #: 417
Don't see why it wouldn't
Yes alex
make sure your motor is set to take that boost!
On full throttle.*wink*
or your in the deep stuff! *frown*
its for my golf - its been setup to run 14-15psi :)
jimmy
Member #: 829
essex
you can bleed it down on the bleed valve i think or i`m wrong ???????
1293 Turbo mini
you can bleed up from the stated amount, but im not sure you can make them produce less boost.. but you can adjust that with the length of the arm..
jimmy
Member #: 829
essex
it runs at 13 so if you are right it will be fun good luck on the biding
1293 Turbo mini
jimmy
Member #: 829
essex
Alex B are you runing 1293 or 1380 turbo
1293 Turbo mini
I'm running a 1293.. but this isnt for my mini, its for my golf. :)
My mini isnt set up yet, but i'm hoping to run 15psi on it.
jimmy
Member #: 829
essex
No i no it`s for the golf
what it was is i`m building a turbo engine and the pistons for the 1293 are the same money as the 1380 but the 1380 is more work ?
1293 Turbo mini
Post your own thread.. ha ha
jimmy
Member #: 829
essex
ok ok ok lol
1293 Turbo mini
