| Home > Help Needed / General Tech Chat > harness bar | |||||||
5th Mar, 2006 at 06:35:12pm
hello anyone know where i can get a safety device harness bar from as i heard they went down the pan, or maybe i was dreaming lol, also what is the best way to weld it on do i need to put plates in etc? thanks, gav |
5th Mar, 2006 at 06:37:29pm
there is a bolt on one that the sevens use.
29 Posts Member #: 707 Member pontefract |
5th Mar, 2006 at 06:46:33pm
make your own and either weld or bolt it on, i made my own and it works fine I do beleve we are on the eve of destruction |
5th Mar, 2006 at 07:03:51pm
ok cheers, did you get my pm iain? |
5th Mar, 2006 at 09:59:14pm
saftey devices are not down the pan - they have however relocated to poland! cheap labour i assume |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
6th Mar, 2006 at 11:08:59pm
just about to do this myself...... remeber to use the correct tubing (cds) normal steel tube is not good enough...... cds can be had from merlins for certain, and at least one other place someone suggested when i asked where to get it from... (completely forgotten now!!) And on the 7th day........... God created turbochargers! |
6th Mar, 2006 at 11:26:25pm
cheers mate |
6th Mar, 2006 at 11:28:26pm
also i was thinking of putting the bar between the two back feet, is this too low ie creates too much of an angle, although saying that most people i've seen mount them to the lower seat belt bolts? |
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
6th Mar, 2006 at 11:46:55pm
Elmdon metals is the place i have seen to use. They do a specific CDS tube which conforms to the minimum outlined spec by the MSA for rollcages. Not got the contact details to hand, but googling should find the contact details. |
7th Mar, 2006 at 12:20:17am
nice one, cheers they can be found here http://www.elmdonmetals.ltd.uk/ |
7th Mar, 2006 at 06:20:43am
Minispares sell them http://www.minispares.com/Product.aspx?pid=38473
7th Mar, 2006 at 10:21:07am
i think these are different, they take up more room including the passenger seat i think. |
7th Mar, 2006 at 10:36:18am
thats the one i was thinking of wil.
7th Mar, 2006 at 11:49:58am
like this |
7th Mar, 2006 at 12:12:30pm
I'd agree with Iani on this. If your seat is way back like mine (my leg is straight with the clutch down and I'm 5' 10") then the harness bar from minispares is a bit too low to get the sholder straps at the right angle.
7th Mar, 2006 at 07:22:44pm
I just bought one from Minispares They're GREAT!!!!
7th Mar, 2006 at 10:23:58pm
any chance of a pic vergard? And on the 7th day........... God created turbochargers! |
8th Mar, 2006 at 11:42:43am
Hmm That takes some organizing... I'll try to get some this week... On 13th Jul, 2012 Ben H said:
13th Mar, 2006 at 12:58:40pm
Pictures:
13th Mar, 2006 at 04:39:31pm
cheers vegard, is there room for a passenger harness as well and do you think i could do without the bar running to the floor? |
14th Mar, 2006 at 07:23:19am
Yes, there is room for a passenger. And you could most definately NOT run without that bar to the floor. If you log on to www.vintageminiracing.com you'll see why.
14th Mar, 2006 at 04:30:25pm
they havent activated my account so i cant read it :( |
15th Mar, 2006 at 07:02:05pm
ah works now thanks just one thing i dont get the guy says: "Secondly is if you use the bolt-on doors bars and other braces you must tack weld the attachment points. In the pics below you will see that on this car the bar pivoted around its connection point which makes it much less strong than if it was solid welded. You don't have to lose the removable feature just weld the attachment clamp" does he mean weld the bar to the car near the door hinge or just weld up the clamp as suely if you weld the clamp you lose the removability?
15th Mar, 2006 at 07:07:12pm
picture says a thousand words: |
