Home > Help Needed / General Tech Chat > Protecting painted arches from paint chips
jamesfawcett
Member #: 218
Bingley, West Yorkshire
i had a problem with my last painted arches and the rear ones got paint chips on them all the time
Is it true that you can get some sort of clear sticker that you put on them? something thats not really visable, but protects the paint? Mine are flip paint thats all and im worried about them getting damaged
Helicopter tape.
Available from most motorsport places, be warned its not cheap but it is good.
Helicopter tape as Tom says but if they have been properly prepped, the paint wont chip.
You dont see any chips on my car (other than where I dropped my hammer on the bonnet landing panel)
Paul
jamesfawcett
Member #: 218
http://www.racerstape.com/heli.html
found it! *happy*
finding a supplier now...
jamesfawcett
Member #: 218
struggling to find someone in the uk that does it less than 6mm thick!!!
http://www.spectorracing.com/catalog/produ...14mil_1x60.html
found them in the usa, if i cant find one in the uk ill just mail order it.
Going to phone merlin motorsport tomorow i bet they might do it
TBH feebs i have the same problem
iam going down you route.
jamesfawcett
Member #: 218
Cool!! well it looks ALOT cheaper to get it from the usa and im recieving another parcel from there soon again so ill get him to put a roll in enough to do your arches too
jamesfawcett
Member #: 218
Right its sorted, hes getting me a roll of it thats 3" wide that should do the front half of our arches. Its probably big enough to do the whole mini its 60"! haha i guess its that long though to do the front of aeroplane wings!
Think ill do the front of my bonnet too, i cant decide whats worse though a couple of stone chips or a ugly plastic sticker
The cost was $90, but i think thats better than paying for getting arches resprayed in flip paint!
jamesfawcett
Member #: 218
Another reason which i also thought of is it will protect the rear arches from accidental petrol spilling, the tape is petrol resistant
jamesfawcett
Member #: 218
Right its on its way benross, and no you can have the tape free of charge im not going to need it all, i dont want any discounts on the head work ive seen how good dannys is and dont mind paying thanks
*oh well* thanks!
Mirage
Member #: 119
Guys, be aware that all helicopter tape is not the same quality. 3m stuff is the best i've used, it sticks better and you can get it to follow bends and contours more easily. Also try using a heat gun to warm it uop when you have applied it, it makes it adhere a lot better.
Mirage
Member #: 119
Forgot to say you can buy it by the metre at trident supplies at silverstone or i think raceparts sell it.
jamesfawcett
Member #: 218
thanks for the tip! yeah was going to have a heat gun to hand when doing it i thought that might work. The heat will probably give more time to get it right too before the glue sticks. Its going to be fun!
Mirage
Member #: 119
The stuff is self adhesive, but some brands seem to peel very easily partic if you try and do 2 radius's at a time. The heat gun seams to kinda semi melt the adhesive and it then sticks much better. Dont use the gun on it as you apply it. Do it in a warm garage as well as it is easier to apply. Hate to think how much of this stuff ive applied in recent years.
cut it to size, peel off the backing, then dunk the whole lot in a bucket of hot soapy water.
this way it can be repositioned easily (just will slide about) and gives you longer to squeeze all the air bubbles out. it will stick just as strong when dry.
this method also works for bonnet stripes, window tinting and door numbers etc
Another tip is to make sure you don't get fingerprints on the adhesive, as you'll always see them.
jamesfawcett
Member #: 218
cool do you think it will work like window tinting film then... I might get a small bit and try it on an old bonnet and see if it dries on well enough
good plan
Mirage
Member #: 119
Very true on the finger prints Tom.
You can spray soapy water onto the surface then apply the sticker, position then push down excluding air and moisture.
