| Home > Help Needed / General Tech Chat > head mods and compresion | |||||||
66 Posts Member #: 775 Advanced Member stourport-on-severn, worcestershire |
14th Mar, 2006 at 08:20:52pm
i have had my chambers ground out by a local company.they recon that they have taken out about 2-3 cc's. so i was going to check using the cd case and oil in a syringe to work out the cc's.
If in Doubt, go flat out !!! |
![]() 368 Posts Member #: 362 Senior Member durham area |
14th Mar, 2006 at 08:37:22pm
i no ml=cc LOL love that straight cut scream!!!
14th Mar, 2006 at 09:53:13pm
the company you chose does not seem to know what thay are doing?
14th Mar, 2006 at 10:27:02pm
cheers benross If in Doubt, go flat out !!! |
14th Mar, 2006 at 10:42:58pm
i correctley modded head is icing on the cake for you with a turbo motor.
15th Mar, 2006 at 06:49:30pm
after checking today i found out the results,
15th Mar, 2006 at 08:57:44pm
Agree with Pete, the difference from cyl to cyl is shocking!!
15th Mar, 2006 at 10:10:37pm
sounds a cracking workshop & guys Edited by BENROSS on 15th Mar, 2006.
16th Mar, 2006 at 07:28:09am
I just cannot at all understand how you 're able to measure the chambers with such accuracy. With my equipment 0,5cc is the best I can do... Talking hundreds is bollox.
17th Mar, 2006 at 12:11:48pm
I agree, I also swap rods back and forth, but 0,5cc does indeed suffice. On 13th Jul, 2012 Ben H said:
