| Home > Technical Chat > Coil over spring rate | |||||||
68 Posts Member #: 596 Advanced Member |
14th Mar, 2006 at 08:37:57pm
Turbo van nearly done now, I am running coil overs all round. I can't find out any info regarding best spring rate for the rear- does anyone here know? |
14th Mar, 2006 at 08:50:16pm
you dont want to be more than 150s to start with if its not loaded up with bloody ICE.
14th Mar, 2006 at 09:20:44pm
No ICE! But may want to move heavy objects at some point-after all it is a van! |
15th Mar, 2006 at 11:45:45am
Refit decent Mini suspension! On 13th Jul, 2012 Ben H said:
969 Posts Member #: 47 Post Whore Not very sunny swanage |
15th Mar, 2006 at 08:03:04pm
pm nic.... hes got rear coilovers, may well be able to give you a starting point
And on the 7th day........... God created turbochargers! |
15th Mar, 2006 at 08:27:08pm
On 15/03/2006 11:45:45 Vegard said:
Refit decent Mini suspension! Helpful as ever Vegard........
15th Mar, 2006 at 11:27:47pm
i have got rear coil overs, ive slated them in the past but im starting to warm to them since setting them up.
16th Mar, 2006 at 08:06:48pm
All the Kits on the market ie Spax, Gaz, Protech are progressive spring, thats all theyll tell you. If you speak to Rod Avon at Protech, he may be able to do you specific rates.
I seriously doubt it! |
17th Mar, 2006 at 07:35:39am
an old europa catalog i have reckons 110 lb ,the grass track coil overs i scrounged have 70 lbs for a much lighter car .hope this helps .regards robert. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
17th Mar, 2006 at 11:37:00am
Refit decent Mini suspension! Helpful as ever Vegard........ I've got my image to take car of you know
