| Home > Help Needed / General Tech Chat > straight cut box | |||||||
119 Posts Member #: 772 Advanced Member new york |
16th Mar, 2006 at 11:35:54pm
i've got two trannys one has 5000 mi. and is from an a+ motor
16th Mar, 2006 at 11:53:33pm
It doesn't really make much difference on the mileage front TBH.
17th Mar, 2006 at 12:25:50am
i really didn't want to touch the a+ tranny because it has only 5,000 mi on it |
17th Mar, 2006 at 12:38:24am
A+ is the one you want for a turbo appl. mainly because of the larger diameter idler (drop) gear bearings.
17th Mar, 2006 at 12:48:31am
damn it a+ tranny it is |
17th Mar, 2006 at 12:23:44pm
My experiance is that the A+ idler are softer ( you should check this Tom) an that the extra leverage the LONG A idler shaft has got compensates for the less diameter. I've seen many times more A+ wrecked idlers than A ones. Myabe coincidence, I think not. On 13th Jul, 2012 Ben H said:
17th Mar, 2006 at 03:03:17pm
Using standard components maybe, but using S/C drops as most of us do I would always build a gearbox from A+ stuff given the choice.
19th Mar, 2006 at 02:52:18pm
