| Home > Help Needed / General Tech Chat > Putting a A+ gearbox on a Pre A+ | |||||||
17th Mar, 2006 at 01:22:00am
I have a 34,000 mile 998cc A+ engine, and my 1040cc pre A+ engine with no gearbox which im turbo'ing.
17th Mar, 2006 at 03:03:55am
You can use all the A+ stuff, just as long as you use the flywheel housing from the A+ as well. The difference is the size of the idler gear shaft size, this fits into the transfer gear casing one side, and the gearbox casing the other side.
17th Mar, 2006 at 01:02:52pm
cool thanks! Ill use all the stuff on the 998cc then. Im going to count the teeth on the diff gears inside to work out the final drive Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
