| Home > Help Needed / General Tech Chat > Gearbox pin removal | |||||||
![]() 2102 Posts Member #: 432 Post Whore Swindon |
17th Mar, 2006 at 08:14:05am
i've searched but found nothing.
17th Mar, 2006 at 08:18:14am
I have never had a problem removing the horizontal roll pin using the correct sized punch and a hammer while its in 3rd gear tapping it out towards the passenger side. -MINI CLUBMAN 1380 TURBO- |
17th Mar, 2006 at 08:18:27am
I do the horizontal one and use one of them tiny metal screw drivers so the blade fits through the hole so it don't slip off
17th Mar, 2006 at 08:19:02am
i HATE doing this, im ultra crap at it too
Edited by Nic on 17th Mar, 2006. |
17th Mar, 2006 at 09:15:11am
i've a little cap head bolt with a nyloc nut through mine for the past 3 years, works fine and only takes 30 seconds to remove On 20th Oct, 2015 Tom Fenton said:
17th Mar, 2006 at 09:31:10am
lol good thinking bud, im gunna replace mine with a bold.
Edited by Mini_Andy on 17th Mar, 2006. |
17th Mar, 2006 at 10:06:14am
i use a ground 6" nail. never fails! ha ha.
17th Mar, 2006 at 11:18:49am
these are a pain most of the time, you get it firs time or you wrestle with it.
17th Mar, 2006 at 11:56:19am
a pit or ramp is the best way to make these easy to remove! forgot to mention that bit.
17th Mar, 2006 at 12:09:46pm
On 17/03/2006 11:56:19 iain said:
a pit or ramp is the best way to make these easy to remove! forgot to mention that bit. its so much harder when you cant swing the hammer properly!!! ![]() aint that always the case |
17th Mar, 2006 at 12:54:53pm
On 17/03/2006 08:18:27 Dangerous said:
I do the horizontal one and use one of them tiny metal screw drivers so the blade fits through the hole so it don't slip off Same here! one of them ones i got free in a cracker, you dont even have to line it up and it comes out straight away Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
17th Mar, 2006 at 03:07:57pm
I don't know why people find these so difficult!
17th Mar, 2006 at 03:46:20pm
or like me if the b@rsted still wont come out then im in a good situation as all ive got to do is remove gear skick, undo 2 nuts and the drag the gear selector out with the engine.
18th Mar, 2006 at 11:42:26pm
well fuck me it came out in the quickest time ever. i found a suitable sized nail (approx 4" length and about the same as the pin) stuck it in reverse hit it once and thought it sounded nice.
236 Posts Member #: 243 Senior Member Portsmouth |
19th Mar, 2006 at 09:52:17pm
I got the pin out no problem with correct size punch, But can i get it back in Can i fudge! Spent 15mins on it last night and gave up so im gonna put a screw in it instead lol! Hope you have more luck getting the pin back in than i did WooHoo Passed it's MOT!!!! One of the cars in The Portsmouth Mini Turbo Massive!!
19th Mar, 2006 at 09:52:42pm
IMHO most of the problems are caused by people forcing the wrong (metric) roll pin into the linkage. As for getting them out I've found the horizontal one is easiest to get out using the correct punch, or a 4.5 angle grinder works well! Isambard Kingdom Brunel said:
241 Posts Member #: 595 Senior Member stoke on trent |
19th Mar, 2006 at 11:46:40pm
i hate that crappy little pin. i also find it a pain in the arse doin the pins that hold the pedals to the brake and clutch master cylinders, then fiddling round getting the split pin in and splitting it, i think im going try a R clip on it next time.
