| Home > Help Needed / General Tech Chat > Another megajolt question | |||||||
207 Posts Member #: 193 Senior Member Aylesbury |
19th Mar, 2006 at 04:43:33pm
At last i am getting around to sorting the megajolt set up onto the car. I am at the moment in the process of getting all the parts sourced. I went to the scrapyard yesterday and got the bits from a sierra. I got the EDIS unit, the coil pack and the crank sensor.
19th Mar, 2006 at 05:05:33pm
the missing wire is a tacho output on the edis module.
Edited by Kean on 19th Mar, 2006. |
19th Mar, 2006 at 05:43:28pm
yeah you can just drill into it, all the stuff is there for it, but im not using it |
19th Mar, 2006 at 05:46:09pm
What are you using for your tac Nic?
19th Mar, 2006 at 06:05:35pm
my ears!! i havent quite figured it out yet |
244 Posts Member #: 34 Senior Member |
19th Mar, 2006 at 06:51:01pm
You can feed the tacho from the low tension side of the coils, by combining the two feeds via 2 diodes. Works with older style tachos that need a high voltage kick to run them.
19th Mar, 2006 at 07:13:50pm
Thanks for all the replies, i am atleast glad that i have not brought something that i can't use. I do recall seeing something on the megajolt website gibbo, have you done this? Is it easy?
19th Mar, 2006 at 07:27:51pm
This is one solution to the trigger wheel-
19th Mar, 2006 at 07:54:37pm
if your like me and a bit of a spaz when it comes to machining you have 3 options
19th Mar, 2006 at 07:57:45pm
I bought a pulley from Tom and it is perfect, def recommend.... and I'd rather give my money to someone who contributes a hell of a lot to this forum than to some company.
19th Mar, 2006 at 09:12:55pm
http://picasso.org/mjlj/?q=node/2 at botom of page shows the diode circuit.
831 Posts Member #: 908 Post Whore gateshead |
19th Mar, 2006 at 10:31:02pm
www.triggerwheels.co.uk
balls to the blower!!!
