Home > Help Needed / General Tech Chat > what exhaust
wethepeople
Member #: 176
Pre-op Transvestite
Felixstowe, Suffolk
Hey guys, i'm looking into buying an exhaust soon but i'm not entirely sure which one to go for. Basically i would really like the playmini twin supersport silencer (the one that has exits either side at the rear) but would this be suitable for a turbo? I'm not if it would be beneficial or not.
What do you think the best one to go for in terms of performance and sound are? I dont want it to be stupidly loud (although someone said the turbo acts as a slight muffler which does quieten it down a bit)
Thank you in advance for your help/opinions :)
giallofly
Member #: 164
The Stig..
Newport Pagnell
play mini or something similar.IMO.
Minishop does something similar, when i bought mine it came free post as the order was over ?117.50, dont know if that offer still applies.
It will be plenty quite enough for lets say the castle coombe noise test, mine is.
you can get cheaper deals at the shows though.
wethepeople
Member #: 176
Pre-op Transvestite
Felixstowe, Suffolk
so would either of these be suitable ?
https://www.midlandwheelsshop.com/view_prod...hp?product=SSEB
https://www.midlandwheelsshop.com/view_prod...p?product=SSETR
or would i be better off going for a single centre exit or the like?
oh yeah, which of the above do you think would sound better? The round pipes, or the boxster?
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
the goods with a turbo is that it is quiet , as the turbine act like a silencer for the exhaust noise,
so you can use the larger and noisy single box n/a one , it will be quieter and will reduce turbo back pressure on a turbo set up
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
americans call them rotory mufflers LOL!
alex
AlexF
1310turbo
Member #: 41
i run a play mini back box, it has a 2inch approx inlet and a 2.5inch ( i think) tail pipe. sounds lovely on tickover, a nice burble
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white|
SumpNut
Member #: 28
My exhaust cost me ?27 from Welsh Mini spares.
Its 2 inch bore strait thru, cheap rusty and chearful
Sounds good tho... *happy*
wethepeople
Member #: 176
Pre-op Transvestite
Felixstowe, Suffolk
hey guys, hows this for good timing.... the exhaust i wanted was on ebay for 120 on buy it now (inc tailpipes and link pipe) so i went and bought the thing
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...DME:B:EOAB:UK:6
thats the one...... i'm gonna cut down the pipes connected to the silencer slightly so that the exhaust isnt as wide as it is standard :)
Edited by wethepeople on 15th Mar, 2004.
