Home > 998cc > 1 litre turbos and ignition setups
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Just wondering, has anyone ever managed to get a 1litre turbo tuned up right tuned using a metro turbo distributer, or is the only right way to do it using something like Megajolt?
I saw one on ebay the other week thats all and they had problems with the running on standard ignition parts.
what did willh use?
thankyou
Edited by AlexB on 20th Mar, 2006.
any dizzy can be locked to prevent advance weights moving then run fixed advance. i'm sure this is the way wil and ben did it before they used MJ/MS.
25 degrees fixed advance should do the trick. wont be ideal by a long way off boost but it all depends on what the cars used for.
Please post in the right sections..
It's an ok section isn't it?
Anyway, yes, we ran at fixed 25 deg and a locked dizzy for a couple of years.
Staggy
Member #: 947
New Zealand
i am running electronic advance of my engine. Seems to work just fine. I have a couple of lucas electronic ignition amps in my spare parts. are they worth anything or are they junk?
Caution !!!! Slippery when boosting
jamesfawcett
Member #: 218
Cool i will get a turbo distributer then and lock the advance. Or will a standard electronic distributer be ok?
jamesfawcett
Member #: 218
oh ok! i didnt know if there were extra parts.
My friend has a Aldon dizzy which he wont be using, if i try buy that off him would i be able to get it set up correct?
jamesfawcett
Member #: 218
Just read an article in the new minimag (thanks T3 tone for encouraging me to buy it! haha)
read about the weights and things so ill get them to stop moving and set the advance to 25 degrees like you.
Im going to try and find out if this aldon one is any good first though
What is the point of spending money on an aldon dizzy that has a custom curve mapped into it with weights and springs when you are going to weld the cunt up solid anyway????
If you are going to go down the clockwork "half a job" weld it up route USE A STD ONE.
jamesfawcett
Member #: 218
ah i get you sorry i didnt realise everything in the dizzy wasnt used and welded up, and i wanted the best :)
Ill get MJLJ but im going to just see how it goes for other people first theres a few of us building 1litre turbos.
Yep thanks so much ill get my distributer welded thanks
