Home > 998cc > 1040cc turbo is it worth modifying the head?
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Hi im in the middle of building my 1040cc turbo and going to be putting it in in the next few weeks hopefully. Im using a T2 turbo with a mirage manifold.
My block is pocketed so i can use a 1275 head. My pistons have a slight dish in them and they are only a few thousand miles old. I was going to get my head chambers made a bit bigger (standard metro turbo head) is it worth it?
Will i be better off using a standard metro 1275 head instead and just giving it a quick refurb? Been reading and looks like this is the way to go.
jamesfawcett
Member #: 218
right sorted then ill give it a go with standard head to start off. Ill give it a refurb though, will standard valve guides be ok?
jamesfawcett
Member #: 218
cool ill get benross to look at it, also taking will's advice on the valve guides and using Avonbar Phosphor Bronze guides
Check the compression with a standard 940 head. If pistons are almost flat, the compression will be sky high with a std head.
Ben H
Member #: 184
Melton Mowbray, Pie Country
The compression is not sky high with a standard head and pockets, but we had the beake removed to get the compression down, and 7cc pistons. Took us to about 8:1. I think some chamber work will be needed if you want to run high boost.
http://www.twin-turbo.co.uk
jamesfawcett
Member #: 218
yeah and benross is going to have a look at the inlets/outlets i think *happy*
jamesfawcett
Member #: 218
cool that would be great!
I've just done a head for a friend, using 19cc head and 6cc pistons. (standard A ones) With the pistons 0,5mm down the bore, the compression is around the 9,5-10 IIRC. Using a 21,4 cc head (std 940) compression will still be over 9. I agree, this is not sky high, but possibly too high :)
