| Home > Help Needed / General Tech Chat > turbo questions | |||||||
35 Posts Member #: 883 Member Shillington, Pennsylvania, USA |
20th Mar, 2006 at 09:35:48pm
I just bought a turbocharged Mini. Supposedly a 1293 with a 286 cam but I think it idles much too smoothly for that cam and anyway the seller told me so many lies I don't know what I have. How can I tell what turbo I have? The only numbers I can see are WPM 1141 and WPM 1143. When I change oil, and I have a 10 row oil cooler, how much oil must I add? How can I really tell the size of the engine? What else should I look out for? Thanks, Slobo "Stick your foot in it" |
21st Mar, 2006 at 09:49:20pm
OK, how about one at a time! How can I identify my turbocharger? The only numbers I see are WPM-1141 and WPM-1143? Thanks, Slobo "Stick your foot in it" |
21st Mar, 2006 at 10:18:17pm
Whats the a/r numbers on the snails,is it a t2 a t25 a t3 or what
22nd Mar, 2006 at 06:13:36pm
That's what I'm trying to find out. The only numbers I see at all are the ones I previously posted and now I see a number SG 7909 on the turbo piece just above the exhaust manifold. "Stick your foot in it" |
22nd Mar, 2006 at 06:27:41pm
example of a/r number on snail
22nd Mar, 2006 at 07:27:49pm
Dangerous, send me your email address and I will send you a photo of my engine. To me it doesn't look like I have a snail. Thanks, Slobo slobartedgon@aol.com "Stick your foot in it" |
22nd Mar, 2006 at 07:31:09pm
mrbugjam@aol.com
22nd Mar, 2006 at 08:15:33pm
Cant see the turbo,It's on the end of the black spring like pipe,No intercooler so don't go over 10psi
Edited by Dangerous on 22nd Mar, 2006.
22nd Mar, 2006 at 09:25:53pm
Thanks, What is the open brass fitting on the right of the first picture near the fuel pressure regulator? Looks like something should be hooked up to it? Is there anyone on this forum near Reading, PA USA? I'd like to get some help with this car. Slobo "Stick your foot in it" |
22nd Mar, 2006 at 09:26:45pm
Also that inline fuel filter, not sure if there designed to take the pressures involved with our set ups? -MINI CLUBMAN 1380 TURBO- |
22nd Mar, 2006 at 09:29:12pm
Where does the pipe under the brass fitting lead to? -MINI CLUBMAN 1380 TURBO- |
23rd Mar, 2006 at 01:51:34pm
OK......... Hard to see but it is about a 1/2 inch rubber hose and goes to a brass fitting in the bottom of the turbocharger on the right side looking at the engine from the front. "Stick your foot in it" |
23rd Mar, 2006 at 01:55:09pm
Sounds like it is going to the side of the compressor housing. The brass fitting should be a T-piece with the other leg having a hose going to the wastegate actuator?
23rd Mar, 2006 at 02:50:14pm
Are there, on this site, any schematics or labeled drawings of a turbocharger like I have so at least I could begin to know what everyone is talking about? Would an in car bleed valve be something I should have? I see that Minispeed sells one. Slobo "Stick your foot in it" |
23rd Mar, 2006 at 02:57:41pm
Not sure if there is one on the site?
1171 Posts Member #: 107 Post Whore Sunny Sussex |
22nd Apr, 2006 at 10:36:27pm
On 23/03/2006 13:55:09 Tom Fenton said:
The brass fitting should be a T-piece with the other leg having a hose going to the wastegate actuator? In any case, the open pipe needs either blocking off, or connecting to a bleed valve. Just the post I was looking for, i have a 3 'legged' bleed valve. Does this go between the brass T and the actuator (with the other leg of the brass T blocked and the 3rd leg of the bleed valve venting to air Or T to actuator on one leg of the T, and the bleed valve on the other leg of the T with the two unused legs of the bleed venting to air? Make sence?? Either way i supposed the bleed will vent and lower the pressure to the actuator?
133 Posts Member #: 703 Advanced Member Plymouth, On the floating skip known as HMS Albion |
22nd Apr, 2006 at 11:15:35pm
On 22/04/2006 22:36:27 Mike said:
Just the post I was looking for, i have a 3 'legged' bleed valve. Does this go between the brass T and the actuator (with the other leg of the brass T blocked and the 3rd leg of the bleed valve venting to air That'll be the one Edited by slim_shadyuk on 22nd Apr, 2006. Whats going to break next!?
23rd Apr, 2006 at 10:33:03am
The open brass fitting sounds like the boost solenoid. If the Metro Turbo ECU isn't fitted then it won't be working, and you will be running 4 psi boost. It is normally closed, 12v to energise and open, so it won't cause any over boost problems if it is left alone.
Edited by metroturbo on 23rd Apr, 2006. |
