Home > Help Needed / General Tech Chat > Rear Drum Brakes
Staggy
Member #: 947
New Zealand
Before we start, yes i have got another haynes manual on its way to me just haven;t recieved it yet. I have forgotten how to remove the rear drums on my mini. I need to remove one to fix one of the studs which has come loose (is a small tack weld a suitable repair)
Any help would be much appricated. Also any cure for siezed brake adjusters. I have them soaking in WD40 hopefully that will cure it.
Caution !!!! Slippery when boosting
Just take wheel off, take out the screw if it has one, and pull them off (wack with a hammer on the side to break the rusty seal if it has one)
Staggy
Member #: 947
New Zealand
thats what i have been trying to do. Might need to upgrade to the next size of hammer. thanks for that
the adjusters screw from the inside of the wheel arch to inside of the drum to take them out.
towards you as you face the shoes!
use a blow torch and get these RED HOT! then go for it with some lube when they have cooled a shade
Just remember 'righty tighty, lefty loosey' !
