Home > Wanted > Intermittent Wiper Relay
Anyone know of a good source for an intermittent wiper relay?
I am using MPi stalks on my car so have the facility to have an intermittent wipe, but the proper MPi mini relay is an arm and a leg.
So after something off another car Ford/Rover whatever? That is readily available!
Or if anyone has one kicking about in their workshop even better.
Ta.
My tip by the way for a good source of normal relays single pole single contact (as used in most applications, e.g. spotlights) is in any Mk2 Metro. They have 4 Hella brand relays in the fusebox to the right hand side of the steering column, they are good quality relays, and more importantly can be harvested from the scrappy for peanuts!
Dangerous
Member #: 417
My metro turbo got them,so I will have a look and see which one it is then I may have one kicking around
Bri, thanks.
Dangerous
Member #: 417
The metro one is top left in the fuse box(1989)
12v 337
wiper control
drc 8534
made by italamec
of to route the garage in a bit
