Home > Help Needed / General Tech Chat > speedo drive mini/metro
Dangerous
Member #: 417
the speedo square inner cable on my metro is smaller than a mini so it don't turn ,as the drive on the gearbox is for the larger mini cable.
Do I have to change the whole end casting(the bit benross put the oil temp sensor in)*oh well*
Kean
Member #: 341
aka T2clubby
South Staffs
No mate, im pretty certain you can remove just the drive unit. IIRC there is a blot just below the cable connector that releases the unit.
Dangerous
Member #: 417
Oh yes you undo the 10mm nut and it pulls out.
Next question do I have to drain the oil to change it or won't it be up that far
It is not up that far, undo the 3/8" head bolt, lift off the forked clamp, then you can pull the drive out.
it took me ages to work out they were different, i just thought i had a couple of bad cables
Well I've just leant something!
I had no idea they were different...
i've had this problem a few times. metro ones tend to always be large, whereas mini ones smaller.
can be a pain to get out if the metal spacer is stuck in though!
Dangerous
Member #: 417
works now speedo pretty much as gear ratio calculator
70 in 2nd
ton in third
