| Home > Help Needed / General Tech Chat > crack head! | |||||||
![]() 102 Posts Member #: 180 Advanced Member Northants |
14th Mar, 2004 at 12:29:04pm
Help please! Just removed my head as i had gasket failure.To find i've a slight crack inbetween 2 valve seats. The head is a full race item with 31mm X 37mm valves. I see that some companys offer repairs! Has anyone else had a repair like this done?And if some was it worth it?And did it work? |
14th Mar, 2004 at 06:05:18pm
id go for a new head to mate no longer a series, but still 1.3 turbo.
14th Mar, 2004 at 08:33:45pm
scrap it...
Edited by AlexF2003 on 14th Mar, 2004. AlexF |
15th Mar, 2004 at 12:51:37am
if this is for a road car, try useing smaller valves on your next head, much les likely to crack. sure someone more in the know wil be able to advise on actual sizes. turbo 16v k-series 11.9@118.9 :)
17th Mar, 2004 at 10:44:20am
I just received a cracked 1275 head. I did carve out the seats to fit hardened seats and then had it pressure tested. No leaks at all.
