Home > Introduce Yourself > Heya
j_d_jag_mini
Member #: 979
Hi i would just like to introduce myself, my name is Jeremy.Im 23 and i live in New Zealand, i have a 1975 turbo'd mini that im in the process of doing it up, it started out as a 1000cc everyday run about and is now a fast but totally unreliable machine thats constantly giving me problems!
Recently the gearbox spat a bearing and stuffed the brand new turbo and some components in the engine,it is now almost ready to run again but i had this problem of the engine cutting out completely after a few seconds under boost of 8psi...and when you back off the accelerator the engine would come back to life again!
Ive been reading some of the questions and comments on here and have already found a few things that could cause it and will change them...like my fuel line sizes maybe to small, and engine timing maybe incorrect. No one knows anything about mg metro engines over here so didnt know where to look until now!
Carb has been rekitted but dont know what needle, Does anyone know what the 2 pipes on the right hand side of carby does? are they fuel returns or breathers or something? Currently i have them linked together with some hose cause it seems to run beter like that.
Thanks, Jeremy
1975 MkIII Morris Mini 1300 Turbo, 100bhp...if only it could run long enough to drive it legally!
Heya welcome. If you do a search, there is a couple of good threads on Carb Connections.
Get some pics up, too :)
Thanks, Jeremy
Welcome, it sounds like you might have the wrong gasket between the carb and plenum, causing the floatbowl not to pressurise under boost.
Hello there welcome to the forum, there is loads of useful information within this site for you!
welcome we are all here to help
like the guys says use the search button!
theres loads of info
if not jusk ask!
T3Tone
Member #: 252
Sunny suffolk
Hello and welcome to the forum
-MINI CLUBMAN 1380 TURBO-
jimmy
Member #: 829
essex
hello welcome tm
1293 Turbo mini
j_d_jag_mini
Member #: 979
Thanks for your kind welcome guys, thats great!
Ive found this website and forum so so useful of the past few hours ive spent on here! so i now have a few more modifications and corrections to do.
Hopefully when i get it running again which will probably be in about 2 weeks...it will run ok....touch wood!
If not...i'll be asking for more help!!!
Thanks again, Jeremy *smiley*
wylyeguy
Member #: 704
salisbury
Hi Jeremy,
Welcome to the club and as all the others have said the info is on the search button.Dave
