Home > Help Needed / General Tech Chat > montego carb
turbo shane
Member #: 982
new zealand rotoura
so would the montego carb be fine to bolt onto the mg metro turbo motor. just checking i no where i can get one for cheap good for a spare. thank heaps guys hard to get any answers in nz .
my mini has a cold
As long as its a Montego turbo, it's the same except for the choke. The Montegos had an automatic choke. You will need to get a conversion kit to manual. This is what I did with mine.
Edited by wil_h on 30th Mar, 2006.
turbo shane
Member #: 982
new zealand rotoura
cheers mate do i need to ajust anything on the carb? like mixture or jus bolt on an start.?
my mini has a cold
Not bolt on and start I'm afraid. Although the car will start the needle will be wrong and you will need a RR session to get one callibrated for your car.
And don't forget what I said above about the choke.
turbochargedstu
Member #: 908
gateshead
hmmmmm. what size carbs are they?? heard that there is a 2" su fitted to some jags. anyone know of these?
balls to the blower!!!
giallofly
Member #: 164
The Stig..
Newport Pagnell
Nope, 44mm just like the Metro..
turbo shane
Member #: 982
new zealand rotoura
about the choke could i swap the mannal choke from the metro and switch it with the montego? it will be hard to get a kit in nz
my mini has a cold
If you have a metro carb then use that. It is exactly the same as the montego item apart from it has the correct choke mechanism on it.
turbo shane
Member #: 982
new zealand rotoura
but the metro carb is stuffed thats why i am changing it
my mini has a cold
but is the choke mechanism ok?
turbo shane
Member #: 982
new zealand rotoura
it looks it will it just bolt on ?
my mini has a cold
Carbs don't just get "stuffed".
It may just need a rebuild.
It is important to get this vital component up to full health, a rebuild kit and a couple of hours will have it good as new.
gregor
Member #: 98
Slovenia
can any one tell me, what is wrong with Montegos automatic choke?
is it not good for turbo mini?
i'm sure its electronic so there is nothing to control it. thats about it really. plus its something else to go wrong! lol!
turbo shane
Member #: 982
new zealand rotoura
also with that choke montego . it gets in the way with the turbo outlet.
my mini has a cold
gregor
Member #: 98
Slovenia
thanks for the answers!
