Home > Technical Chat > piston valve contact help please
i looked at my engine today, pistons 2+3 have had valve contact its very light and you cant feel any damage to the piston when running fingers over them
im shitting a brick now! this was with mg cam and 1.5 rockers, my new build has about 10 thou less on the piston to deck height and i am now running a ph2 cam
is there any other reason for this? scattered timing? my setting tappets wrong? overrevving? there was no contact evident last time i lifted the head
does this mean i have to get pistons machined?
there is also cracks between 3+4 just evident in the pic, i am not bothered if this engine is scrap what i am worred about in the new engine will i have to go back to mg rockers? with the ph2?
Edited by wolfie on 30th Mar, 2006.
How the F**K have you managed that on an A-series???
This is not possible as the valve has to lift at least (assuming a VERY skimmed head) 5mm off the seat before reaching deck level - and I don't know what cam can do that in the 50/60 degrees before TDC that it starts to happen - unless your cam timing is a MILE off ????
its possible dave i did not do the engine bought as is, its got steel lightened duplex gears and is clearly lightly rebuilt
would it not run though if the valve timing was out? it drove reasonable
T3Tone
Member #: 252
Sunny suffolk
Is the timing chain still on to be able to check?? Seems very strange
-MINI CLUBMAN 1380 TURBO-
Leonard
Member #: 806
Cirencester, Gloucestershire
piper reccomend standard or 1.3 ratio rocker with the phase two.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
I have a NA engine with std pressed steel rockes (highest lift) STR930 cam, and 13,5 cc head(skimmed lots), pistons flush with block deck. with this setup I am still 1 mm clear from the pistons with the valves.
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
Edited by fab on 30th Mar, 2006.
turbo hogster
Member #: 178
stowmaket suffolk
pistons may be ok , mine has had a bit of contact but that was through over tightened tappet when adjusting for the first time but it did just mark it rather than when running.
yes mat i will get the cover off in the morning
Dangerous
Member #: 417
Between 2 and 3 is the hottest part of the engine,if cooling is a bit lack could be the valves sticking a bit in the guides
I was going to sugest this too. if igniton timing was out, then it would get hot and th guides could nip up a little.
turbo hogster
Member #: 178
stowmaket suffolk
i concer as wolfie told me that it was just 2 and 3 which was marked so sounds about right.
i will go with valve seizure in the guides on 2 & 3
Created by fueling & or ..Ignition timing, too HOT! *frown*
for me the piston on the left shows signs of detonation and is starting to break up!
i would not trust these further IMO.
the above needs addressing on you next build. *smiley*
what guides & valves were used wolfie?.
SumpNut
Member #: 28
I had an exhaust valve pinch up on me. However the damage I got was much more severe (bend valve and very dented piston)
It would be well worth checking out your valve stem to guide clearances and making sure they are not too tight
Dangerous
Member #: 417
or that thing in the boot*wink*
giallofly
Member #: 164
The Stig..
Newport Pagnell
Garranteed seizure, make sure those guide are well reemed especially if they are bronze.
JF.
What is it with Jon and reaming....
The man's obsessed!
hoggy reamed my hole so the shaft wont stick
cheers hoggie
turbo hogster
Member #: 178
stowmaket suffolk
yes they were tight on the reamer but didnt seam to bad with the valve in but should be ok now as long as that fuel and ign is correct.
