Home > Help Needed / General Tech Chat > pulley part number
t3gav
Member #: 229
Gavin@minispares.com
kent
hello, anybody know exactly what pulley we need for the megajolt setup ie the pulley we need to send to tom as there seem to be a few differences between them, might be able to get them a little cheaper if someone knows the minispares part no and would prob save people some hassle in trying to find them, thanks gav
jimmy
Member #: 829
essex
PM tom he will tell you what pully you need to send him
1293 Turbo mini
t3gav
Member #: 229
kent
sorry done that, but he went offline just wondering if anybody knew so i could get prices by tomorrow *happy*
Just replied to your PM.
The pulley is the standard 1275 A+ damper pulley, also fitted to 1098 engines I believe.
I enquired into new ones, price is around £150!!!
Too expensive IMO.
t3gav
Member #: 229
kent
ah cheers tom, dont suppose its dropped a lot in price since lol http://minispares.com/Product.aspx?pid=32836
Blimey, that is approaching reasonable!
If they had been that cheap when I looked I would have bought a new one for sure.
t3gav
Member #: 229
kent
is that the right one then, i should be able to get them cheaper :)
t3gav
Member #: 229
kent
sorry that looked like i was taking the piss, not that i didnt believe you just went to find the actual price and thought i had the wrong one lol!
Yes that looks like the right one.
The part number stamped into the standard ones is TAM2011 but that certainly looks right and also the description is correct too.
t3gav
Member #: 229
kent
cool, will let you know asap
Woa.. I do remember these being £150 a few weeks ago as a matter of fact!
Yes, I am sure it was only just before Xmas when I looked and they were £150-odd!
t3gav
Member #: 229
kent
yep they are tam 2011 *happy*
As far as I know the crank tail sizes are the same on all mini cranks? As a duplex timing gear kit for example fits all A and A+ engines.
Amp
Member #: 7856
Thread revival, is the TAM2011 the best option to fit for a 1293 with a bolt on trigger wheel or does it need any machining / auxiliaries?
