| Home > Help Needed / General Tech Chat > Few questions | |||||||
2nd Apr, 2006 at 01:12:13am
Hi, been looking through alot of old threads, but some replys contradict each other, so just got a few (well several) q's for you guys, not sure if its personal preference or a simple case of right or wrong so...here goes...
2nd Apr, 2006 at 01:23:34am
On 02/04/2006 01:12:13 joeybaby83 said:
ok in my opinion: 1 ) Should the dumpvalve signal be plumbed in before or after the butterfly? AFTER, im off the manifold 2 ) Should the boost gauge be plumbed in before or after the butterfly? AFTER,im off the manifold 3 ) If both of the above reside on the same side of the butterfly, can i use a t-piece, or drill tap separate take off? basically do they affect each others function if ran off a t piece? unsure, probably doesnt but id prefer seperate for reliable gauge readings 4 ) Im sure the actuator plumbs into the compressor housing, but just want to double check- thats what i do, but i think i read about someone taking it off the plenum 5 ) Im aiming at running 10-12psi boost.... I think I should i get a higher rated actuator, say a 14 psi actuator, and use more preload, but... some people have a lower rated actuator and use a bleed valve? From what ive read, TD (or Miniwilliams? cant remember now) and Benross have differing veiws on this. -if you get a 14psi actuator you will have 14psi, unless you run it with poor preload, id get a 10psi one and use a bleed valve to up it 6 ) Giallofly pointed out some cheap bleedvalves on eBay the other week (these had 3 takeoffs), i presume these fit inline on the actuators signal pipe from the compressor housing ( ? ) but where do you plumb the 3rd take off to? leave that to vent to the atmosphere |
1300 Posts Member #: 829 Post Whore essex |
2nd Apr, 2006 at 09:38:19am
All sounds good to me
Edited by jimmy on 2nd Apr, 2006. 1293 Turbo mini
51 Posts Member #: 979 Advanced Member Auckland, New Zealand |
2nd Apr, 2006 at 11:57:03am
I wouldnt bother changing the actuator for another one that has a different psi setting......just do what i did and fit a dual stage in car boost controller, it sets the pressure for the actuator to release the wastegate.
1975 MkIII Morris Mini 1300 Turbo, 100bhp...if only it could run long enough to drive it legally! |
2nd Apr, 2006 at 01:43:15pm
Those electronic boost controllers look very tasty, but are a bit pricey for me...
Edited by joeybaby83 on 2nd Apr, 2006. "Turbo's make torque, and torque makes fun"
2nd Apr, 2006 at 07:43:32pm
dump valve goes on engine side of throttle butterfly so doe's the boost gauge if you want it to show positive and negetive boost
2nd Apr, 2006 at 08:21:12pm
I'm with dangerous on the actuator signal from the plenun.
2nd Apr, 2006 at 09:15:55pm
Cheers guys, done a bit of reading on this...but still a bit hazey on how to have dual boost settings.
2nd Apr, 2006 at 09:33:37pm
In my opinion, the best way to do it is to decide what boost you want to run, select a suitable actuator, and then leave it alone!
2nd Apr, 2006 at 09:37:39pm
thought so, cheers tom
2nd Apr, 2006 at 10:26:45pm
I can get air valves too do the job that will run 8bar all day long so will up to the job
1293 Turbo mini
3rd Apr, 2006 at 12:25:13am
Like tom - If you're going to run 10psi, then set it for 10psi and have done with it. There is absolutely no need to vary between 4 and 10psi - your right foot does this better than some 'blingin switch. If your mini is weaving and snaking at 10psi; DO accept that you haven't got something very special, it's just that your suspension geometry is all to cock...
3rd Apr, 2006 at 08:09:59am
If you do run a boost controller electric or manual.....choose one that has a gated system if you can,they are beter.
