| Home > Help Needed / General Tech Chat > gearbox q's | |||||||
3rd Apr, 2006 at 06:14:43pm
Do you guys replace the needle roller bearings for 1st 2nd and 3rd gears?
AlexF |
3rd Apr, 2006 at 07:02:48pm
I replace them when i change the component they're rotating against - eg when fitting my new gearkit I replaced them. Whenever it comes apart for inspection, I leave them (including the orientation) if everything looks ok. But if i needed to change (say) 2nd gear, then I'll also change the corresponding needle bearing.
3rd Apr, 2006 at 07:31:50pm
Same as Dave really, if new components are being used then change them as a matter of course, but if the same bits are going back in the same place, just a thorough inspection to make sure they are OK is good enough for me.
3rd Apr, 2006 at 07:53:01pm
Make sure you keep the orientation of the bearings though...
3rd Apr, 2006 at 10:06:13pm
On 03/04/2006 19:53:01 TurboDave said:
Make sure you keep the orientation of the bearings though... In the same manner - the ends of my idler are marked inner and outer so it always runs the same way... new bearings it is this time then LOL! AlexF |
