Home > Help Needed / General Tech Chat > Mounting Fuel Pump
Ric
Member #: 36
Basingstoke
I've got a metro turbo fuel pump to bung on the mini, can't work out the best way to secure it though. Do they need to be rubber mounted? I heard the vanes in them were pretty sensitive...
How has everyone else done this and where have you mounted it?
Thanks for the help. *happy*
Kean
Member #: 341
aka T2clubby
South Staffs
Mine is mounted on the rear subframe, bolted on via rubber exhaust cotton reel mounts.
Job done.
Nick
Member #: 154
Midlands
yup, mines the same. been fine for the last 2 years.
arse, that reminds me i need to change my fuel filter...
Jackman
Member #: 984
Westhoughton, Bolton
If you solid mount them ive heard they are very noisey.
Manchester Minis
Ric
Member #: 36
Basingstoke
sorry for the daft question, but how did you join the cotton reel mount to the pump?
on the mutro they have a clamp, like a coil clamp which actually you may be able to use!
Ric
Member #: 36
Basingstoke
cool, i'll start hunting.
Thanks for the help guys.
SumpNut
Member #: 28
My metal bodied filer has rubber insulation around it - around all of this I have fitted a standard coil clamp. I then bolt this to the car
I used a coil bracket, then mounted this on rubber exhaust bobbins.
Phil. *smiley*
Carl
Member #: 95
liverpool-on-sea
Phil. *smiley*
me to mines in my boot tho
ive got some pipe clamps that i aquired from work, its not quite right and damn noisy, but they have an m8 bit to bolt them down and the clamps are lined with rubber
Phil. *smiley*
Mines in the boot to ! *tongue* lol
adam1330
Member #: 238
essex
mines in the boot, mounted on the original bracket with rubber exhaust bobbins.
fortfun
Member #: 954
Fort Collins Colorado USA
The pump I bought has big warnings against mounting it in the boot. You certainly can understand that bad things could happen if a hose developed a leak and you had 20psi gasoline spraying around in there with the battery. I'm going for subframe.
1275 with Back Door Turbo
My pump has the rubber tube around it like Sumpnuts, and Iv'e just tiewrapped it to the subframe with a fucking big tiewrap.
Carl
Member #: 95
liverpool-on-sea
fortfun i do see exactly what you say but my pipes run through the car as well. and with the tank in the boot anyway i dont see that much more of a risk really to be honest*smiley*
Edited by Carl on 6th Apr, 2006.
My pipes run through the car too *happy*
If you build it properly, you shouldnt get any leaks.
I'd use cable ties..
Carl
Member #: 95
liverpool-on-sea
cable ties or gaffa tape its all good..
couple of nails
