Home > Help Needed / General Tech Chat > boost
turbo shane
Member #: 982
new zealand rotoura
hay all . when motor is ideling and then u rev it is the boost gauge ment to show any boost ? or only when driving
my mini has a cold
The turbo will only really produce boost with the engine under load, e.g. driving along.
If you rev it high enough it may make the gauge flicker a little but that will be about it.
turbo shane
Member #: 982
new zealand rotoura
cool thanks
my mini has a cold
Ric
Member #: 36
Basingstoke
depending on where you've taken the feed for the gauge from, you should see vac on idle...
j_d_jag_mini
Member #: 979
Yea i agree, depends where you run the pipe from for the guage, my boost needle movement no different rev'd to that under load and thats tapped into carby manifold.
Jeremy
1975 MkIII Morris Mini 1300 Turbo, 100bhp...if only it could run long enough to drive it legally!
t@z
Member #: 452
Chester, UK
just quickly, is boost anything zero plus or is it counted as 10 psi when idle (mine is around -10) and the needle reaches zero?
T
www.twitter.com/lilpinkiy
the -10 is a vacuum, 0 is atmospheric pressure as a NA would see, then anything above zero is what the turbocharger is providing. so 10 on your gauge would be 10psi boost *smiley*
t@z
Member #: 452
Chester, UK
Cheers just me and a mate was pondering that as we couldn't work it out.
T
