Home > Help Needed / General Tech Chat > Avonbar carb spacer for DV???
Jim
Member #: 125
I'm wanting to fit a DV and have seen the following:
ABR8010/1 Modified carb' spacer: Modified carburetter spacer with vaccum adapter fitted for connecting dump valve. ( longer manifold studs needed ) ?16.95
CHS2514K Stud kit Longer inlet manifold stud/nut kit for modified spacer. ?6.55
If I get these 2 things does that mean I won't need to drill a hole in my plenum??
Jim
you will still need to drill a hole in your plenum, this is just for the vaccum pipe
Jim
Member #: 125
Ah. Where do the rest of you take the vacuum feed from then?
I take mine from the servo takeoff as i have no servo :)
(or atleast i used to and i will again!)
Jim
Member #: 125
Servo - as in brake servo, yes?
Yep, there is the take-off in the middle of the inlet manifold.
Anywhere on the inlet manifold is ok though.
Jim
Member #: 125
I know the take-off you mean. Would it be ok to just fit a 2 way adaptor to this take off or is it best to drill and tap a new one?
If you go and root out your local scrapyard, Montego/maestros have the same 'banjo bolt' as fitted to the metro turbos, but rather than having a 1/8BSPtaper hole tapped in the top, has a 4mm pipe sticking out - ideal for fitting a dump valve to!
That's my reccomendation!
Id put a seperate one on if it was me. there is a flat, round cast circle on the inlet perfect for tapping into. :)
