Home > Help Needed / General Tech Chat > duplex or simplex
Dangerous
Member #: 417
duplex or simplex timing gear for mg n/a cam in a turbo,is it better to have more accurate timing with the duplex or save a bit of wieght (and the revolving mass thing) and just use the single chain.
Will be using normal rockers to start with(cast or a series steel with welded top) then 1.3 rollers eventually
Always duplex! The simplex ones stretch far too much.
Yep, duplex.
Skinns46
Member #: 165
Cambridge
Yeh, duplex. You could always lighten it a bit if your that way inclined.
http://photobucket.com/albums/y139/Skinns46/
i must have 7 or 8 simplex's bobbing about, might start making clocks out of them and sell them on ebay
Dangerous
Member #: 417
Best put a duplex on then,just thought that with the mildish mg cam a simplex would suffice
giallofly
Member #: 164
The Stig..
Newport Pagnell
It will do the job but i have a new set if you are interested.
Cam timing is free power, just do it right!
Ask the Wolfmeister...
JF.
jimmy
Member #: 829
essex
I had a simplex break up on a engine so for me it`s a duplex all day long !!
1293 Turbo mini
i have a good s/h duplex you can have if you want?
i also have a not so great vernier thats going on egay soon
