Home > Wanted > A+ Small Bore S/C Drop Gears
For my 998 Turbo, there were loads on ebay before xmas, and none since!
Id be gratfull for just the Primiary Gear to be honest.
Jo
Mike
Member #: 107
Sunny Sussex
how will you fit a S/C primary with non S/C drops?! :)
Dangerous
Member #: 417
The other two are the same as 1275 at a guess
ive got a spare s/c idler, and an old s/c input (which id prefer not to use really)....
Mike
Member #: 107
Sunny Sussex
u cant fit a s/c primary with standard drops!
Just be careful here, not all s/c gears are the same..........
ahh, in that case has anyone got a complete set?
Jo
That would be the path I would go down, unless you are VERY lucky, three odd drops are unlikely to match as a set.
i thought they were all cut the same, i.e. involute...?
Mike
Member #: 107
Sunny Sussex
i got mine from moorspeed :) £200 for the set if i remember right.
