| Home > Help Needed / General Tech Chat > Radius Arm Bearing Bush Reamer | |||||||
14th Apr, 2006 at 11:23:42am
I am thinking of buying a reamer for the radius arm bearing bushes.
100 Posts Member #: 745 Advanced Member Northampton |
14th Apr, 2006 at 01:16:35pm
long series 13/16" parallel hand reamer..
14th Apr, 2006 at 01:26:30pm
Thanks Dave.
19th Sep, 2006 at 04:22:20pm
Has anyone done this? is it an easy job? Team www.sheepspeed.com Racing
667 Posts Member #: 1376 Post Whore clock tower with a sniper rifle |
7th Dec, 2010 at 07:38:03pm
wich one of this bad boys do i need?
internationally known as "big" swede |
7th Dec, 2010 at 08:10:15pm
From a quick glance, none of those.
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
7th Dec, 2010 at 08:28:56pm
On 19th Sep, 2006 Jimster said:
Has anyone done this? is it an easy job? Yes Jim. Success on 4 occasions using the proper Rover radius arm bearing reamer tool however the tolerances once complete are rather slack - good for getting grease in and at least the hole is round not oval. Paul - if you wanna borrow the tool I'm sure we could sort something. Richard. Minivanless, but reluctantly happy living with the decision. There'll be another one day.
7th Dec, 2010 at 09:45:22pm
with the aid of a conversion chart i finally find one Edited by G13B on 7th Dec, 2010. internationally known as "big" swede |
9th Dec, 2010 at 05:23:29pm
i used similar to above a few times and seem to have gotten away with it, but....ideally you should use the proper tool or equivalent to make sure your ream both bushes parallel
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
9th Dec, 2010 at 06:12:27pm
IMO an adjustable reamer is a must! Or at least very, very desirbale! We measured some shafts and they differed quite a bit in dia.
[X] nail here for new monitor |
9th Dec, 2010 at 06:33:57pm
will try to do something like that, Asphalt
9th Dec, 2010 at 06:44:46pm
my proper ghetto style method is a radius arm shaft with 6 slots cut in it and a taper on the beginning with a nut welded on the other end looks abit like a fat drill bit.
Yes i moved to the darkside |
9th Dec, 2010 at 06:50:50pm
@G13B: Hmmmm - if you make it two-piece, why not? On the arms I did, the shaft never fittet through the unreamed bush... But if you connect the reamer with the shaft 'in situ' - why not?
Edited by Asphalt on 9th Dec, 2010. [X] nail here for new monitor |
9th Dec, 2010 at 07:31:37pm
maybe use the old needle layer and do the reaming first, then clean… internationally known as "big" swede |
9th Dec, 2010 at 08:33:26pm
Has anyone ever thought about fitting a second needle bearing instead of the plain bush?
Edited by Sprocket on 9th Dec, 2010. On 26th Oct, 2004 TurboDave16v said:
89 Posts Member #: 2380 Advanced Member Hamburg, Germany |
9th Dec, 2010 at 08:59:18pm
IIRC the later aussie mokes used 2 needle bearings, and the Metro/114 arms uses 2 of them.
16th Dec, 2010 at 09:14:25am
On the shafts i have replaced the needle bearing side have been most damaged, you can see where the rollers have eaten them self in, unsure if this is a cause of bad lubrication or not… i guess the bronze bushing have a larger contact area and can withstand more force, some racers put in 2 bronze bushes and get rid of the needle bearing completely*.
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
16th Dec, 2010 at 05:31:59pm
I have tried both an adjustable reamer and the proper Churchill tools for removing the bearings & bush, replacing them and then reaming to size.
Metric is for people who can't do fractions. |
16th Dec, 2010 at 05:58:21pm
Didn't the very early arms have two bushes? [X] nail here for new monitor |
18th Dec, 2010 at 12:56:56pm
Only the other week did I actually get a reamer to do this job.
19th Dec, 2010 at 07:03:24pm
is this what you have been looking for.
339 Posts Member #: 399 Senior Member Austria |
20th Dec, 2010 at 11:25:22am
Harry has got a tool like this.
