| Home > Technical Chat > gearbox limits?? | |||||||
15th Apr, 2006 at 12:55:53am
hi
My build thread..
15th Apr, 2006 at 03:02:50am
If you're gentle with the transmission - and don't use full boost in 1st (which will be difficult anyway as it's so short) and second, and try accelerating IN the gears, rather than crashing 'through' themm you should find the trans will stand up to quite a lot of abuse - following an 'every bearing' rebuild.
15th Apr, 2006 at 03:14:01am
For me the course of upgrades should be 4 pin diff as a must really.
82 Posts Member #: 9772 Advanced Member Sheffield |
26th Jan, 2012 at 01:05:54am
Similar query as this.
26th Jan, 2012 at 07:11:25am
sc drops are not necessary , i run up to 250 bhp with no problems on helical drops ,its 3rd gear that breaks on the helical gearbox at about 135lb/ft of torque,if you drag race the box and use it fairly enthusiastically. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
26th Jan, 2012 at 08:22:23am
i disagree Robert. s/c drops with a helpical box for much more than standard metro turbo power and either with a s/c gearset.
26th Jan, 2012 at 09:26:14am
I'd tend to agree with Robert.
26th Jan, 2012 at 09:49:26am
Robert & sprocket
26th Jan, 2012 at 09:52:28am
Oh and probably worth mentioning it's only going to be used for road use with my 2.76 final drive. Never dragged or raced |
26th Jan, 2012 at 11:02:07am
For example Wintersurfer is putting around 160nanas through and old Clubby GT helical box with X pin and SC drops.
In the 13's at last!.. Just |
26th Jan, 2012 at 11:19:03am
Haha I have also posted another Thread about my exact query and has made up what is starting to be quite an argument between theory's.
26th Jan, 2012 at 01:07:55pm
Edited by robert on 26th Jan, 2012. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
26th Jan, 2012 at 01:36:27pm
My personal THOUGHTS/OPINIONS on the matter:- (I make no scientifically backed claims or guarantees)
26th Jan, 2012 at 01:49:18pm
Ill bet that when using heli gears and drops that when the drops have been stripped its being down to the 4th gear/input bearing collapsing or failing causing the input gear to try and climb the idler. Now wether that failure has been caused by twisting effects/side loads assosiated with helicle drops s debatable. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
26th Jan, 2012 at 02:31:16pm
This is all great advice cheers.
26th Jan, 2012 at 03:11:08pm
If your helical drops are in good condition, you get the primary gear endfloat right and shim up the idler correctly, yes. If something is worth doing, it's worth doing half of. |
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
26th Jan, 2012 at 07:31:23pm
justa note, im on a 2.7, with Full S/C setup, and its not actually that bad, i use it everyday...... On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
26th Jan, 2012 at 08:14:30pm
On 26th Jan, 2012 rubicon said:
justa note, im on a 2.7, with Full S/C setup, and its not actually that bad, i use it everyday...... But that is an individual point of view. Some people can tolerate the noise more than others. Some people are deaf, some are hard of hearing somewhere between deaf and perfect hearing, whether they realise it or not, and some just cannot tolerate the high tone whine from straight cut gears, while others are perfectly happy with it. we know which catagory you fall into, but is can that be said for the original poster? On 26th Oct, 2004 TurboDave16v said:
26th Jan, 2012 at 10:12:43pm
I battered my ears with loud music when I was a kid, so my full SC is easy to live with.
26th Jan, 2012 at 11:09:10pm
Robert thanks for that. Octet reading those mind is made up. New gear set it is. |
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
26th Jan, 2012 at 11:17:08pm
On 26th Jan, 2012 John said:
If your helical drops are in good condition, you get the primary gear endfloat right and shim up the idler correctly, yes. This is an important point, regardless of which combination you chose. |
26th Jan, 2012 at 11:22:30pm
I will double check this with my Mechanic. I'm popping in to see how he's getting on with it tomorrow. |
155 Posts Member #: 9226 Advanced Member Rushden |
31st Jan, 2012 at 10:32:31pm
just out of interest, when using a helical box, to make it slightly stronger you put in sc drops.. but if you have a sc box you can use helical drops to reduce noise but surely your putting a weak link in the transmission and taking a step back? can someone clear this up as i dont understand the logic i got nothing but time.. |
![]() 130 Posts Member #: 9395 Advanced Member |
1st Feb, 2012 at 12:33:36am
From the comments, it seems that a SC box is not a great deal noisier than a helical box
Edited by ntm1275 on 1st Feb, 2012. |
1st Feb, 2012 at 08:54:04am
On 1st Feb, 2012 ntm1275 said:
From the comments, it seems that a SC box is not a great deal noisier than a helical box So why are sc drops so much noisier than helical ones Is it down to the fact that they are not continually submerged in oil like the box is something to do with the super sonic speed the oil passes them.....or some bollocks....
