Home > General Chat > What oil pressure do you RUN???
Just wondering what oil pressure (when warm/hot) do people have at tick over and at 3000 rpm and above??
as people say so many different things.
MW
Doodmeister
Member #: 149
Alberta, Canada
I have a 1450 and it runs at 70psi at 3000 and around 50 at idle when hot. Rev it to 4000 and above and it goes to around 90 psi.
Engines never missed a beat and the baerings look great when i just rebuilt the motor. and it's had a hard life the last 15 years.
Karl.
Edited by Doodmeister on 20th Mar, 2004.
evolotion
Member #: 83
Glasgow, Scotland
prob not much help, but my car when hot runs 50@3000 and 25 on very very very hot idle(i.e. after an hour at 4500RPM on the motorway), normally around 30-35 if im sitting in traffic/town.
thats a 1380 with the "turbo" oil pump from minispares.
Denis O'Brien.
When warm, i aim for 50-55psi at full bore. This of course drops to 25-30 psi at idle, but that's more than enough!
Some aim for really high oil pressures, each to their own, but I've never 'lost' a big end/mains shell in the 6 years i've had a turbo or the 3 years previous playing with fast road A-series motors...
Each to their own!
Edited by turbodave16v on 21st Mar, 2004.
1310turbo
Member #: 41
mine is roughly the same as daves, around 50-55psi at idle, cant remember the exact figures for rpm over idle.
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white|
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
mine are the same as dave... although thats just what it is I havent set it...
too much oil pressure puts excess strain on oil seals.
alex
AlexF
evolotion
Member #: 83
Glasgow, Scotland
"around 50-55psi at idle" that isnt the same as daves *tongue*
Denis O'Brien.
cheers chaps, and Dave i know you have said that all along but just wanted to see what else people have, by the way i'm the same as Dave and the others (pressure wise) also with a M spares turbo oil pump.
cheers Guys
MW
I'm not using a minispares pump anymore - especially seeing what it looked like when i took it apart.
Got the Avonbar pump instead. Not cheap at 50 quid incl delivery, but those minspares ones really are lousy...
Nick
Member #: 154
Midlands
ive got 12.5psi above 3000rpm and about 1psi at warm idle in my N/A 1275. i wonder why its having the turbo lump put in mid june ready for showdown.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
LOL!
does it rattle nicely?
alex
AlexF
I get 45psi when hot on idle and rises to 55 when reving it
cheers jim:)
