| Home > Help Needed / General Tech Chat > What do i get welded up in the dizzy... | |||||||
16th Apr, 2006 at 12:34:14pm
Sorry just to make sure, on thie distributor to get a fixed 15degrees advance so i need the weights welded up, or just the advance? The guy thats doing it for me has just asked me on a pm and want to make sure.
16th Apr, 2006 at 12:45:26pm
http://www.minifinity.com/index.php?name=P...ewtopic&t=40291 Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
16th Apr, 2006 at 12:57:34pm
15 degrees isnt very much. |
16th Apr, 2006 at 01:30:07pm
I think thats what will used though on their 998 turbo and i want to do the same because it works Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
16th Apr, 2006 at 02:08:43pm
well you'd better check your facts them because 15 degrees won't work. On 17th Nov, 2014 Tom Fenton said:
16th Apr, 2006 at 02:37:19pm
No we had it fixed 25 degrees advanced. http://www.twin-turbo.co.uk
16th Apr, 2006 at 04:53:43pm
weld the weights so they dont move then you can fix the ign timing to what ever you want.
16th Apr, 2006 at 04:56:48pm
Here is an idea, why not take the distributor to pieces and work out which pieces would move under centrifgal force, and then not only will you know which bits to weld together, you'll have learned something about how the dizzy works as well.
100 Posts Member #: 745 Advanced Member Northampton |
16th Apr, 2006 at 05:11:35pm
if feebs getting the dizzy off me (and I'm welding it up), was just confirming what was needed to be done to it.. Have locked off the vac advance stuff. Never the whole lot (but then I dont tend to play with turbos!! :o )
16th Apr, 2006 at 05:13:16pm
cool will do tom, the guy that im buying it off though has offered to weld it for me (icklebits on minifinity) so ill get him to do it his end.
16th Apr, 2006 at 05:25:53pm
icklebits or icklemini? we are different people!! |
16th Apr, 2006 at 05:29:55pm
You want to weld it up to achieve no CENTRIFUGAL advance.
17th Apr, 2006 at 07:33:16am
With my fixed dizzy, I removed the vacuum advance and chucked it in the bin (well the spared pile) http://www.twin-turbo.co.uk
17th Apr, 2006 at 08:14:08am
i just didnt plump mine in, but i did once and the engine didnt like, when on the rollers it sent my hc levels from 430 to over 3000 , weid,
17th Apr, 2006 at 08:49:55am
I inadvertantly locked one once by having too long a screw holding the points in,took a while to work out why the car wasn't going to good
