| Home > Help Needed / General Tech Chat > clutch oil seal problems | |||||||
263 Posts Member #: 115 Senior Member Austria, near Vienna |
20th Apr, 2006 at 06:29:09pm
Bimmer Twinky headed and turboed A-Series:
20th Apr, 2006 at 07:02:31pm
this may help you??
20th Apr, 2006 at 07:21:40pm
sounds like the "luf" one is the one to go for. |
20th Apr, 2006 at 07:30:57pm
I've used the black one for the past few years. And taking the engine apart this year - not even the slightest sign of leakage.
20th Apr, 2006 at 08:03:58pm
The last few years my seals started to leak after about 4-5000km after assembly. This was at the end of the season so I didn't care too much about that, because over winter i am always refurbishing my engine. I am also using the full floating bush which is at its end at the end of the season so I didn't wonder myself too much.
20th Apr, 2006 at 08:18:38pm
i wonder though with the increased lip pressure you may get increased wear or even heat to an extent it will damage the seal? |
20th Apr, 2006 at 08:24:17pm
Way I see it; seals are designed by peeps who's job it is to design seals.
20th Apr, 2006 at 09:39:41pm
the black one have been known for problems with the spring. It has dropped of the lip in the seal sometimes. I think the best bet is to try to get a steel backed one from GACO or similar.... |
21st Apr, 2006 at 06:15:22am
I know that some people are increasing the spring pressure - of course this will reduce its life but be honest - how many miles do these seals life in our engines?! Bimmer Twinky headed and turboed A-Series:
21st Apr, 2006 at 07:47:29am
ive used the black one and woirks well.
21st Apr, 2006 at 08:31:45am
ive used the black seal from the injection minis for years and never had a problem. well the only problem was getting one from Rover, the guy kept saying they only use the orange one, then he found it on the computer and found its about 4 times the price.
21st Apr, 2006 at 08:38:04pm
my thoughts are the same as dave on this one harry.
21st Apr, 2006 at 09:34:25pm
Hi benross,
100 Posts Member #: 745 Advanced Member Northampton |
21st Apr, 2006 at 09:50:55pm
I supply the black seal with all the gearbox/transfer case jobs I do.. not had any comeback on them (touch wood!)
22nd Apr, 2006 at 08:11:31am
also you have to make sure the oil release holes in the primary gear are not blocked and the outer bush isnt worn as this will spill oil into the clutch as well. always looking for them bigger bunches of bannanas |
22nd Apr, 2006 at 06:19:56pm
Mounted the black seal today; did about 100km today - problems seems to be solved; maybe I had a bad luck with 2 orange "monday morning" seals?! Bimmer Twinky headed and turboed A-Series:
31st Aug, 2006 at 12:59:04pm
Sorry to drag up an old post, but my black seal did not even make it off the drive.
31st Aug, 2006 at 01:25:26pm
Oil pressure doesn't affect the life of this seal one bit. I guess most of the failures on said seal is incorrect fitment. Not saying you did, but generally. On 13th Jul, 2012 Ben H said:
31st Aug, 2006 at 02:08:55pm
To get the seal out drill two little holes 180deg apart, then screw in a small self tapper which can then be pulled with a pair of pliers to remove the seal........
31st Aug, 2006 at 02:27:00pm
Tried that Tom, but with the engine in the car, I can't get a drill in.
31st Aug, 2006 at 02:40:16pm
Ah right yes of course. I have an angle-drill that runs off the air line that is handy for this kind of thing.
Edited by Tom Fenton on 31st Aug, 2006.
31st Aug, 2006 at 02:46:14pm
i've got the proper tool and to be honest for the price it makes things very easy and i've never had any issues with leakage.
31st Aug, 2006 at 07:40:07pm
On 31/08/2006 14:46:14 iain said:
i've got the proper tool and to be honest for the price it makes things very easy and i've never had any issues with leakage. Only takes one seal to be put in dodgy and scrap a clutch plate off and the tool has paid for itself. ![]() I second that. As far as I was concerned the cost of the tool paid for itself the first time i used it. Incidently the seal was the last thing to go in after building up the engine, plenty of grease on the primary gear and also on the spline sleave tool. As for getting the seal out, pull the primary gear out On 26th Oct, 2004 TurboDave16v said:
31st Aug, 2006 at 08:03:09pm
i had a problem with 2 minispares crank seals leaking just before avon, they were orange ones. in the end i went to m&ms and got a cheap nasty looking one it cured my leak, odd.
31st Aug, 2006 at 08:07:08pm
I went to minispares this afternoon and bought the tool.
