Home > Introduce Yourself > Rotary Muffler Install underway
fortfun
Member #: 954
Fort Collins Colorado USA
Should be done and tuned next week. :cool:
Edited by fortfun on 22nd Apr, 2006.
1275 with Back Door Turbo
Staggy
Member #: 947
New Zealand
thats insane but i like it. Am interested to see how it all goes
Caution !!!! Slippery when boosting
And your setup is hardly conventional staggy!
That is an interesting solution, good luck and welcome
Staggy
Member #: 947
New Zealand
i wasn't having a go. 10/10 for being different. i have never seen anything like it before. i look forward to more info.
indeed!keep us posted
very interseted in this since the rear kits came out dfor the v8's be great to see how the lag is on a smaller engine ,what a/r you using ? the smallest i imagine ,well done that man .regards robert.
what a twist, are you using an uprated exhaust manifold and pipes or are they the generic ones?
Good luck with it!
fortfun
Member #: 954
Thanks for all the interest. I'm working with the guys in Utah who have the patent on the rear turbo installations. Plan is to work this up as a kit once it's all sorted. Turbine A/R is .35. Exhaust up front is an SPI cast iron manifold with Maniflow downpipe. It had an RC40 as well. Was intending to keep the front box, but now gone, we'll see if a post-turbo muffler is needed.
The patent info is here: http://patft.uspto.gov/netacgi/nph-Parser?...RS=PN/6,745,568 It explains some about how oiling is handled and the passive intercooling from the long intake pipe.
The boost pipe is going to run up around the front of the engine. Considering adding an explicit intercooler.
Carb is a Weber 32/36 downdraft. I had it on normally aspirated, and found it easy to tune. Carb bonnets are also readily available.
Engine is a Metro LE piece, supposed to be 9.4:1 compression. I've never pulled the head, but it certainly runs well and doesn't use oil. Will be putting in a conservative tune on the Dynojet. Naturally aspirated it runs fine on 87 US octane ( (R+M)/2, roughly 91RON). I have 91 octane (~95RON) readily available. Goal is to produce a tidy bolt-on turbo setup. The plate for the oil pump mount is welded on, but I think could be done without welding.
jimmy
Member #: 829
essex
looks good BUT what if it rains ??
1293 Turbo mini
" fortfun
Member #: 954
Fort Collins Colorado USA"
That should answer your question!
I might be wrong, but i think that Colorado has two seasons: Winter and Summer.
I recall FF asked my opinion on this some time ago - and I said don't go bigger than a 0.35 turbine... That said, I'd love to have a ride in this, to see how it compares to the 0.35 of the stock R5GT unit... Maybe it'll take a bigger turbine? Maybe the compressor can be modified to suit... Either way - sounds like he's got himself forever hailed as a TM innovator - the first to try something very different. Good show that man.
Edited by turbodave16v on 23rd Apr, 2006.
jimmy
Member #: 829
essex
ok :cool:
1293 Turbo mini
fortfun
Member #: 954
Well, it does rain here occasionally. The air filter is nestled up against the floorpan, and away from the wheels. There is a spot to tuck it up behind the rear valence panel. If it winds up sucking in water I'll try that.
Thanks for all the kind words. Now hopefully it actually works too...
Edited by fortfun on 23rd Apr, 2006.
jimmy
Member #: 829
essex
were`s the exhaust box fitted ?
1293 Turbo mini
Kean
Member #: 341
aka T2clubby
South Staffs
Your looking at it lol, hence the term "rotary muffler"
I do like that install, seen it on a few american cars now, be very interesting to see what the lag is like.
sparkyp
Member #: 988
Woodley nr Reading
Very nice to see im all for a change from the norm good luck.
You don't know till you try it !
slim_shadyuk
Member #: 703
Plymouth, On the floating skip known as HMS Albion
Definately one thing you wouldnt wanna catch on a speed bump!
Whats going to break next!?
Turbominis Worst Advice winner 2006, get in
very funny slim ,nice to start the day wiv a laff.
i forgot to guess the turbo ,,,gt20?
Can't really say anything that hasn't been said before, you've got to try things! good on you mate, keep us posted.
fortfun
Member #: 954
GT15, with 0.35 turbine A/R. Expect to fire it Thursday or Friday.
hat off to you
great! just great !.................please keep us posted
for got to mention...... "neat work too" *happy*
personally ............................................................................ i would sort the intake to a safer place for water ingress if it happens
Edited by BENROSS on 27th Apr, 2006.
fortfun
Member #: 954
Frustration reigns right now. Waiting on parts.... silly silicone couplers of all things.
Yes, the pipes look great. Professional job, and well done I think.
Edited by fortfun on 28th Apr, 2006.
bet your dying to see what its like!
if you were thinking about this conversion, but live in a rainy area, i reckon it would be relatively easy to bring the whole set up into the boot...
beestje007
Member #: 1230
yehh in the boot next to the gasoline *smiley*
