Home > Help Needed / General Tech Chat > cleaning an intercooler
evolotion
Member #: 83
Glasgow, Scotland
best methods?
just been tryign to clean up the one i have got and flush it out (both inside and out) as want air flowign through it freely on the outside, and dont want any shite that may be on the inside getting into my engine :) is there any particular houshold cleaning products that are good at gleaning but leave ally alone?
found a paint brush is soft enough to not damage the fins but it isnt strong enough to shift soem of the crap between them *angry*
any ideas?
Denis O'Brien.
SumpNut
Member #: 28
could you soak it overnight in soapy water to losen the dirt.
Then maybe flush it out with a hosepipe?
evolotion
Member #: 83
Glasgow, Scotland
certainly give it a try, jsut worried about the salt in soap tarnishing / corroding the ally. i want it to work well, but want it looking good too *tongue*
Denis O'Brien.
slim_shadyuk
Member #: 703
Plymouth, On the floating skip known as HMS Albion
Well if you rinse with fresh water afterwards you'll have no worries of salt corrosion :p
Perhaps you could use high pressure air to blow through the fins and remove stubborn dirt?
Whats going to break next!?
Turbominis Worst Advice winner 2006, get in
flush the inside through with petrol
jimmy
Member #: 829
essex
steam cleaner degrease or traffic remover pour it in with boiling water 50/50 mix for half hour then wash out with hot water
1293 Turbo mini
evolotion
Member #: 83
Glasgow, Scotland
On 22/04/2006 22:42:08 jimmy said:
traffic remover
would that work on the motorway at rush hour? *tongue*
on a more serious note i know TFR can be pretty corrosive stuff, or is it all safe for ally? not questioning the advice, jsut curious. its currently soaking in hot soapy water
*wink*
Edit ^^ all traffic film removers.. sorry was a bit vague. if not is the ra particular brand i should be looking for?
Edited by evolotion on 22nd Apr, 2006.
Denis O'Brien.
jimmy
Member #: 829
essex
Ha Ha Ha yes TFR is corrosive but you are using it 50/50 and FOR HALF / HOUR and by washing out with hot water will remove all the TFR from the cooler so you will be ok
1293 Turbo mini
evolotion
Member #: 83
Glasgow, Scotland
cheers. :)
Denis O'Brien.
DON'T use a powerfull hose or pressure washer. You'll bend over the fins before you know it - which isn't great for flow.
Anyone want the T-shirt? LOL
evolotion
Member #: 83
Glasgow, Scotland
dont have access to either, and jsut spent a good 20 mins straghtening every bent fin wiht a screwdriver, so ok on that count *happy*
Denis O'Brien.
