| Home > Help Needed / General Tech Chat > What size wheels? | ||||||||||
24th Apr, 2006 at 10:43:45pm
What width handle best on the road/
24th Apr, 2006 at 10:53:20pm
Basically I'm looking to convert to 10 Inch wheels and I'm trying to work out the optimum width for handling. If I go for wheels that are too narrow then there will be too much tyre roll, which is not good, but if I go for wheels that are too wide it will offset the centre of the wheel outside the axis between the ball joints, making the car more prone to tram lining and bump steer. I realise that tyre choice will also play a part and I’m looking at going for 165 Yokos, but I may be persuaded to change my mind if someone puts a good case forwards other wise. I must stress I am interested in handling on the road here, not looks and not getting the best time on the quarter mile. Isambard Kingdom Brunel said:
11th Nov, 2006 at 02:01:59pm
6" is the way to go
11th Nov, 2006 at 03:32:59pm
For 10" wheels I would stick to 5" wide for the road using 165/70/10 tyres.
11th Nov, 2006 at 04:27:47pm
On 24th of Apr, 2006 at 10:53pm British Open Classic said:
but if I go for wheels that are too wide it will offset the centre of the wheel outside the axis between the ball joints Why ? That happens with spacers,If the wheel is widend evenly(inside and out side) It should be ok
11th Nov, 2006 at 06:03:06pm
That's indeed correct, but normally 6" wheels go as far in as it's possible. The last inch then MUST go outwards. On 13th Jul, 2012 Ben H said:
11th Nov, 2006 at 06:39:17pm
On 11th of Nov, 2006 at 06:03pm Vegard said:
That's indeed correct, but normally 6" wheels go as far in as it's possible. The last inch then MUST go outwards. That was my thinking. Isambard Kingdom Brunel said:
13th Nov, 2006 at 01:57:09pm
Im using 10 X 6 wellers, they seem to be offset to the outside a fair amount compares to other 10 inch alloy wheel ive seen.
13th Nov, 2006 at 01:57:35pm
13th Nov, 2006 at 02:16:05pm
I prefer 10*5 to use for 165 70 10
