| Home > Help Needed / General Tech Chat > Idle Problems & Soggy Handling | |||||||
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
26th Apr, 2006 at 09:04:11am
Hi all, picked up a mini 30 yest. It's a nice car, but there's a few things i'd like to sort before newquay.
26th Apr, 2006 at 09:09:34am
crack out the haynes manual and raise the idle....
AlexF |
26th Apr, 2006 at 09:13:30am
Check front subframe floor mounts, also front teardrop mounts.
26th Apr, 2006 at 09:51:22am
teardrop is the one about the suspension cone isn't it? and are the floor mounts the ones that bolt to the floorpan? I'd like to solid mount everything really. Might pick up the bits at the show...
26th Apr, 2006 at 09:54:09am
Tear drop behind bolt hole in front valance
26th Apr, 2006 at 09:57:13am
Increasing the idle is done by removing the airbox, there is a cross head screw head you can see from directly above the carb, front radiator side if my memory is correct.
26th Apr, 2006 at 10:36:29am
cool, thanks tom, will sort the idle tonight then.
26th Apr, 2006 at 10:39:34am
Depends if you order it today for next day delivery, and then fit it tomorrow/friday night.
![]() 2102 Posts Member #: 432 Post Whore Swindon |
26th Apr, 2006 at 10:51:04am
they don't take long to fit mate....... |
26th Apr, 2006 at 11:35:15am
no? i assumed it would be an arse of a job to do.
26th Apr, 2006 at 12:05:53pm
the only problem i ever find is getting to the top teardrop bolts..... Edited by Mini_Andy on 26th Apr, 2006. |
Site Admin 6302 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
26th Apr, 2006 at 01:07:43pm
the teardrops are easy - I can pop over and help if you want bud |
26th Apr, 2006 at 01:07:59pm
or we could take the frog.. |
26th Apr, 2006 at 01:32:40pm
we'll see how badly i break the 30 first |
26th Apr, 2006 at 05:11:40pm
Just had a call from minisport. They can't get my bits out for tomorrow. Scrap that idea then!! Looks like i'll be buying some in newquay. |
26th Apr, 2006 at 05:15:05pm
The answer to that dilemma? DON'T USE MINISPORT THEY ARE FUCKING SHITE!
Thanks all. :)
