Home > Wanted > Valve Stem Seals
I need a set of valve stem seals to go on my brothers inlets. I looked in the garage last night (as I knew I had some) and unfortunatly I've only got 3.
Has anyone got a spare one getting all lonely in a corner somewhere?
Wil
52p from minispares if you get stuck :)
Is that right.
I've never found anyone who sells them seperatly, hence why I asked the question.
Wil
Yeah, i ordered some last week as the head sets only come with 4 and i prefer to fit a set of 8.
Carl
Member #: 95
liverpool-on-sea
my exhaust valves dont have any stem seals on them at all apparently the dont need them.
the guy at avonbar rekons to use good used seals on the exhaust stems
i stripped my old head twice and put new stem seals on and twice they ended up popping off and sticking on the top off the valve stem *tongue*
Edited by Carl on 23rd Mar, 2004.
Even if they go up and down with the valve they should prevent pil running down the valve stem.
For the price they cost its just as easy to put 8 on :) also depends which guides you use i think as some have a groove which the sprung stem seals sit in nicely.
:) each to there own mind :)
I have heard that if you put valve seals on sodium filled valves, that the rubber gets pinched in the larger valve and the valve can stick
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
clear Jim , we can't use genuine valve stem seals as they are to tight to fit the larger sodium filled stems, think that Rover/bl/mg were not time less to fit valve stem seasl on the exhaust valves, they simply doesn't need them
