Home > Help Needed / General Tech Chat > roll cage bolts and coilovers
nutter driver
Member #: 47
Not very sunny swanage
just a quicky. do the bolts need to be high tensile or are the standard 8.8 ok? the question applies to all the bolts, ie the bolts throught the floor and the bolts that hold the different parts of the cage together.....
also, the coilovers ive got second hand, the bolts that go through the top arm and the top mount are well fubared... same question as above... do these need to be high tensile or will 8.8 be ok?
Pete
I'd say it is worth using high tensile bolts for the cage, especially where two parts of the cage join together.
And for the coilover bolts definately use high tensile, think what will happen if one breaks....
8.8 are high tensile. 8.8 is what is specified in th Blue Book, so stick with that.
nutter driver
Member #: 47
really will? i was under the impression that 8.8 were normal and 10.2 was high? wonder why i thought that?
regardless, if 8.8 is whats specified, then 8.8 is what it shall get, cheers for looking it up mate..... think i might get the nastiest oes i can for the suspension though....
thanks guys....
Pete
here is a little chart that I just googled.
http://www.roymech.co.uk/Useful_Tables/Screws/Strength.htm
yes, you can get stronger than 8.8, up to 14.9 it appears. But in my experiance you can generally get 4.8 and 8.8 from suppliers; 8.8 being considered the high tensile and 4.8 low.
I've never seen anything above 8.8; although they obviously exist.
Most decent capheads are usually 10.9 or 12.9, these are pretty common so I am suprised you have never come across any! These are what I use, especially for roll cage joints.
I work in the dark ages of the railway though Tom. where 8.8 is king. But I'll jkeep my eye out.
8.8s are easy up to the job though.
Ben H
Member #: 184
Melton Mowbray, Pie Country
As far as I am aware 8.8 is standard automotive. I think I am right in saying that the SVA test only requires 8.8 for even things like seatbelt mounts. I guess this is a minimum requirement though.
http://www.twin-turbo.co.uk
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
8.8 is industry standard...
In terms of roll cages, its also the bolt Safety Devices supply.
Alex
AlexF
jimmy
Member #: 829
essex
I`ve used 8.8 bolts on roll cages for years and i`ve had one or two cars on it`s roof i`ve never HAD a bolt fail
1293 Turbo mini
but what about shear strength? i was under the impression high tensile had less shear strength ?
Dangerous
Member #: 417
8.8 will bend a bit,14.9 are strong but tend to snap under a sideways load
nutter driver
Member #: 47
so in that respect am i better off sticking with 8.8s for the suspension bits as well? bearing in mind that all of the bolts in question are horizonatl and thus under a shear load?
jimmy
Member #: 829
essex
up to you mate *wink* *wink*
1293 Turbo mini
nutter driver
Member #: 47
cheers jimmy!!!! lol
