Home > General Chat > Newquay Help! ...... one of the cornish lot
Need a part for a wiper motor, the long wire bit, emma has snapped hers and may not be able to get home if it rains
also anywhere i can get a clutch done on a pug 405 tdi 1996 around newquay? if not ill have to call the AA lol
i poss may not be able to get back online as in internet cafe but Alex Nicky Alexf and Jon have my number so if you can help with the wiper part can you give me a ring? |(sorry guys dont want to post number up on forum)
if you need his number, PM me.
how long you down there for mate?
thanks for the replies
we are sorted! great mini community we have here :)
i am down till friday Jim
Wolfie what is up with the clutch? Has it suddenly started slipping?
If it is oiled up from a failed crank seal, get it stinking hot and then pour a can of Coke (proper Coca-Cola, Roller Cola won't do!) down the bellhousing, it will scour the oil off the clutch plate, may just get you home.
SurfToLiveLiveToSurf
Member #: 748
Cirencester, Gloucestershire
You sorted now?
1310 - Supercharged 16v Twin Cam - 190BHP - SC Built.
1293 - Turbo 16v Twin Cam - Build Commenced
Ric
Member #: 36
Basingstoke
tom, you really have earned that macgyver pic!! Where did you learn about that little gem?
My days Rallying.
You do whatever is needed to try and get the car to the end of the event. Including replacing a broken rear suspension strut with a length of steel pipe "borrowed" from a close by road sign......
At least it is not changing a driveshaft lying half in a ditch, yes been there done that.
no clutch is fubarred no oil leaks just wear and tear
cornish hills did it in
pulling away is the problem once on the move its fine, lisa drove the mini to the m5 while i towed the empty trailer, we then loaded up the mini and sat on the moterway just trying not to slow down anywhere, have been told by previous owner (owned for 6 years) that he never replaced the clutch, car now has 164k on its so not done to bad
Its not too bad a job to do it, did the one on mine about a month or so ago, give me a shout if you need any advice on doing it etc.
im not sure what to do with it tom
Mot is till Oct and it still has 4 months tax BUT ....
1)Clutch is totally fcuked
2)dent in side and i cant open 1 of the rear doors
3)i am sure it needs a cambelt as "its not been done for a few years"
4)when i hit 4500 rpm when towing i get very thick black smoke out of the exhaust
really not sure if its worth fixing it or scrapping it and getting something else if i can afford it, sometimes its better the devil you know as it drives lovely once ive got it started
Cambelt is piece of piss, I have done maybe 20 to 25 of these Pug diesel engines, I have the locking kit you can borrow if reqd.
Also I am not suprised it puts clouds of shit out at 4500rpm, with mine I find it is not really worth revving it much past 3500rpm as the power tails off, you are much better changing gear and using the torque in the next higher gear. At 4500rpm you are approaching the governor, which is why is starts to throw out sh1te!
Clutch not horrendous, kit for mine was only £65.
Also try a new set of glow plugs in it to help it start. I put a new set in mine last week and from starting on 3 cyls and putting out clouds of black/blue smoke that made me suspect the turbo was u/s, it now starts lovely with only a bit of a puff of sh1t. When I tested the old plugs, 1 was completely u/s, another was slow to heat up. These were only 12 months old as well, spending £23 on a set of glow plugs saved me getting another turbo for it.
glow plugs are new
only hit 4500 because of them bloody cornish hills lol and did not want to change up because of the slipping clutch
