Home > Wanted > Metro Turbo Clutch Casing
MiniTurboBadBoy
Member #: 483
Merthyr Tydfil
Hi im need the clutch casing which attaches to the side of the engine as mine is damaged. Any one got one as spare?
Thanks Chris.
How is yours damaged? If it is just the starter motor casing broken off, then I would get this repaired by TIG welding. The proper turbo side casings with the larger bearing housing are getting rare now.
MiniTurboBadBoy
Member #: 483
Merthyr Tydfil
Yes its just the starter motor casing thats damaged i didnt know the casing could be welded though
if you can get the casing to bridgend or cardiff, I can get it welded for you
MiniTurboBadBoy
Member #: 483
Merthyr Tydfil
great ill pm you when i got off just waiting for an excuss to take the engine out first.
