| Home > Help Needed / General Tech Chat > turbo oil seals | |||||||
568 Posts Member #: 102 Post Whore Pennsylvania USA |
24th Mar, 2004 at 11:48:04pm
Hi |
24th Mar, 2004 at 11:58:59pm
how much oil is there? Team www.sheepspeed.com Racing
25th Mar, 2004 at 12:08:29am
Hi
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
25th Mar, 2004 at 06:59:11am
Check to see if any of your breather system connects into your air inlet pipes. This is quite common practice as it would allow oil to be burnt off, it would also show up on the bores of the pipes.
25th Mar, 2004 at 07:26:52am
this make me think of a burned turbo...., you should rebuild your turbo with a rebuild kit, it will stop the oil to leak in the turbo wheels hsg. you can also try to reduce the oil pressure at your turbo inlet, as turbos don't like high oil pressures, they just need flow (good oil), 4 psi's are ok. this will help to keep the oil inside the oil passages and stop splashing in the comp turb wheels side.
25th Mar, 2004 at 10:18:09am
How do I reduce the oil pressure at the turbo. Is there some sore or reducer and if so where do i get one?
263 Posts Member #: 115 Senior Member Austria, near Vienna |
25th Mar, 2004 at 07:00:26pm
Hi Fab, you mean 4 bar not 4 psi, right?
Bimmer Twinky headed and turboed A-Series:
25th Mar, 2004 at 08:41:46pm
Ok. I took off the plenum chamber to make it run with out turbo and this has stopped the clouds of smoke coming from the tail pipe. It's got to be the turbo. Does anyone know of any workshop manuals that show how to strip and rebuild a turbo? And will a rebuild kit for any T3 be Ok?
26th Mar, 2004 at 06:35:22am
not , Harry, 2.5 bar are only needed to well lubrificate the turbo bearings , but they need a constant highflow ( good quality oil pump and very high quality oil , I'm using motorbike 15w50 racing oil)
26th Mar, 2004 at 06:51:04am
sorry harry have answered too fast, evidently 4 psi's are a lot insuffisant,
