| Home > MS Trials & Testing > max RPM with EDIS system? (megajolt) | |||||||
6th May, 2006 at 10:03:27am
whats the max RPM that the EDIS system is capable of? and whats stopping it from turning even quicker? |
1171 Posts Member #: 107 Post Whore Sunny Sussex |
6th May, 2006 at 10:34:08am
sure i've read its around 9000-10,000
6th May, 2006 at 10:35:38am
okay, will be around my redline then... whats making the EDIS or coil pack or whatever give up then? |
6th May, 2006 at 11:01:36am
It is basically to do with the processor speed on the MegaJolt board will not support computing the advance quickly enough at high engine speeds I believe.
6th May, 2006 at 11:07:45am
Dont think the Megajolt is the problem, its the EDIS unit or the FORD coil that cant cope with it. I have tried investigating a bit on the brent piccasso (sp?) site. |
7th May, 2006 at 10:18:17am
Its the EDIS that is the problem not the coil pack. I think it is just to do with processing speed of the EDIS, either it can't process the speed of the input from the timing wheel or it can't switch the coli fast enough. Safe to say, whichever it is it is the limiting factor. I have a mate running a it on an Imp engine that pulls over 9000 with no problem. If you want to rev further you will have to ditch the EDIS and choose another ignition system that the MS/MJ offers.
http://www.twin-turbo.co.uk
7th May, 2006 at 10:28:46am
okay, any idea what other ign. system that may work with the MJ? |
7th May, 2006 at 02:05:41pm
none will...
AlexF |
7th May, 2006 at 02:45:04pm
Yep, you can use the V3 MS and run it with just a crank trigger but you'll need to add another coil triggering IC circuit to the unit. On 28th Aug, 2011 Kean said:
7th May, 2006 at 03:15:24pm
thanks, this will not be a problem I guess, as I stopped at around 8500 last summer, but tried 9300 a few times. We will try with MJ and see how it goes, I bet it will be just fine. its for a 1071 BTW |
