| Home > Help Needed / General Tech Chat > Turbo Rebuild Advice | |||||||
461 Posts Member #: 91 Senior Member Live @ Worksop, Work @ Rotherham |
7th May, 2006 at 09:31:52pm
I got a rebult kit (cheers Iain) and have two Turbos, one i bought of e-bay descibed as a good used one, actually loads of play in shaft.
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
7th May, 2006 at 09:34:23pm
i would say the one that doesnt move much would be the best bet, soak the bearing housing internally for a bit with meths or some thing like that and get it turning to se what the play is in that one first "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
7th May, 2006 at 10:32:18pm
Difficult one to call. With the one with play in it, make sure 100% the blades haven't been touching the casing.
12 Posts Member #: 1025 Member |
8th May, 2006 at 12:42:14am
Dismantal one turbo at a time, , soka the bearing housing in a seal bucket filled with petrol. On the compressor side, check the carbon seal, make sure you remove it, cause it doesn't like petrol. If your turbo doesn't have a carbon seal on the compressor side, then you must have a piston seals on it, carfully inspected the circumfrence of the piston ring groove, and see if any small cracks appears..., do the same for the turbine shaft, there must be a piston seal, or air seal.
8th May, 2006 at 11:34:56am
Id sort out the worse one first, as youll end up with one good one and one with play, rather than one good one and one thats still unusable (not that im saying you should use a turbo with play in the shaft, but if it works, it works..) "Turbo's make torque, and torque makes fun"
