Home > General Chat > Front anti roll bars
Anyone had any experiance of them?
I know of two that are available for the Mini, KAD and Minispares. Any knowledge of these would be nice or are there any other options?
Wil
email Endaf Endaf@owensfabrication.com he makes and sells them, but he will give you an honest opinion of them,
i have one fitted on my car. can take some pics if you like *smiley*
not sure how effective it is!
Ben H
Member #: 184
Melton Mowbray, Pie Country
The only reason we did not fit one before is because we didn't have an LSD. There is no reason why not to get one now.
http://www.twin-turbo.co.uk
My car doesnt have an lsd either. there must be some advantage to having one otherwise i cant see them fitting it.
its on a miglia so its never had an lsd fitted. not sure if they all use one?
for what you use the car for wil, i'd not bother .
i tried one years ago, admitidly it was a thick bugger and it caused me to literally understeer in a straight line. and even over slightly bumpy roads under power it had the front wheels skiping all over the place.
so i removed it and the car gripped like a goodun,
if you really want your car sorted book it into terapin services,it'll cost you mind but it'll be a different car once all the alterations Alan recomends are done.
carl
carl
Edited by fastcarl on 8th May, 2006.
SidewaysGTM
Member #: 5022
Oxford, Kings Lynn, Pod, Pub.
Did a quick search and came across this but need more info, can anyone with a Mini spares antiroll bar take some measurments for me? would like to know width lever arm lengths etc so i can work out the bar rate and add it to my suspension calcs i am doing at the mo.
Got A GTM With A Honda In the Back, and huge Nitrous bottle where the passenger seat should be when racing!
On 19th Oct, 2009 Nic said:
Ill donate to the cause if you can make it do wheelies!!
width 750mm
lever arem length 380mm (adjustable, mine is set shorter than this)
bar diameter 19mm
Is this what you need?
SidewaysGTM
Member #: 5022
Sweet
Thanks just the diemensions, was that the minispares kit by chance?
WEST
yes MS one
SidewaysGTM
Member #: 5022
Does anyone have any pictures of a Front Adjustabe Minispares Anti roll bar fittted, ideally a pic from underneath and side?
WEST
