Home > Help Needed / General Tech Chat > is my box a genuine turbo box?
daniel_johno
Member #: 751
Aberdeen
Ive started stripping my gearbox for a rebuild and removed the diff and counted the FD. I calculated 3.44:1 but i thought the turbo box had a 3.2:1 FD or am i wrong?
on one of two of the big gears (dont knwo which is which) there is a bit of kink in everytooth as if something has rubbed on the gear as it has been spinning and worn away at it abit. If anyone can understand the above would this require a new gear set?
Once i find my digi cam ill take a pic and post pics of it as also on the tiny thin gears next to the baulk rings most the teeth are mashed off aswell so its not looking good!!!!
Thanks for looking
Dan
Pictures please...
well it sounds f**ked enough to be a turbo box.... If that makes you feel any better? LOL
Seriously - consult a haynes manual for the correct description of the parts you're describing, and/or pics...
some gearboxs (A+ i think...prob wrong though) have a notch along middle of the teeth of one of the cogs.
the turbo box should have a 3.2:1 diff, and a larger diameter nose bearing, dont know the measurements off hand.
All A+ gear sets are destinguised with a notch on the tip of each teeth on at least one of the gear pairs
Dangerous
Member #: 417
Some boxes have 2 rows of notches,that being the econemy set
andeh
Member #: 97
Near Daventry, midlands
some have none, being pre A+
daniel_johno
Member #: 751
Aberdeen
ok on refering to the haynes manual it is the straight cut gears attached to the 1st and 2nd gear that the synchro sleeve slots into. they are about 3-4mm wide. Basically most the teeth are mashed off, so am i right in thinking that the gearbox is past it!!
How readily available are replacement gears and gear sets or will it be easier to try source another A+ box and start fresh?
Thanks for all your input
Dan
Dan
The gears you refer to are not gears but the synchro engagement teeth. They are not supposed to look like a gear, TAKE US SOME PICTURES and we can give you a much better opinion!
daniel_johno
Member #: 751
Aberdeen
dont know how to post pictures so they can be viewed at ...
if the link doesnt work let me know and ill try again.
Dan
ps i apologise for the quality, they where taken on phone as digi cam is knackered.
<Edited to show pics. TF>
Edited by Tom Fenton on 9th May, 2006.
