Home > Help Needed / General Tech Chat > T3 Turbo
colas
Member #: 102
Pennsylvania USA
Hey
Will any T3 Garrett fit a mini or are there different versions.
Thanks
Colas
There are different versions. For example, the Escort RS Turbo uses a T3 but this is different.
Phil. *smiley*
colas
Member #: 102
Pennsylvania USA
Hi
Have you any idea what cars have the same or is it just the metro thats the same?
Colas
the metro was unique I belive
colas
Member #: 102
Pennsylvania USA
What about repair kits. Are they the same?
Colas
I'm not sure, but I bet Fab will be along soon, he'll now
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
the main housing of each class of turbo ( T2/T25; T3 /T4, t04 etc...) share the same bearings , seals..;etc so a rebuilt kit for a Tb03 will be used by all the familly, as it only contain, the main housing rebuildable parts, if your wheels, wheels hsg are worn, then you'll need a core to have them.
fab
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
The RS Turbo T3 has a bigger exh housing, other than that its idenitical.
If you get a rebuild from turbo technics and that turbo happened to need a new exh housing (they crack) then you end up with a RST one anyway as the metty parts are no longer availble.
Alex
AlexF
Im having a bash at rebuilding a turbo ive got, doesnt appear to be bad so hopefully it should be ok. It didnt cost me anything so ive got nothing to loose!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
untill you put it on the engine... the bladees fail and go into the inlet...
becareful is the message :)
alex
AlexF
Yep, careful is my middle name
now where is my BFH???
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
LOL @ bfh
birmingham screwer you mean :p
AlexF
